A/C won't shut off
Discussion in 'International Forum' started by earnies2, Apr 8, 2021.
  1. earnies2
    earnies2 Medium Load Member
    691
    281
    May 17, 2012
    Dedham, MA.
    2009 Prostar ISX. I just fixed a leak at the shrader valve and also changed out my thermosters . A/C compressor wouldn't come on.... I read the long post about the A/C not working and Heavy d had the answer it was a bad connection at the fuse A/C works but doesn't shut off . Even if i cycle the bcm ( i have a switch) and I have tried it also with the key. So if I put the dial on hot and the controller on dash or floor the compressor stays running.... any thoughts would be appreciated
  3. Six9GS
    Six9GS Road Train Member
    1,473
    3,697
    Dec 3, 2012
    Yuma, AZ
    Stay South so you always need your AC.
    Real answer is I'm sorry IDK. I know my way around car AC and plenty of car wrenching experience, but haven't worked on any rigs before, except for assorted service tasks I did when I was a kid working a gas station that was the closest thing to a truck stop my little town had. Found out where the term grease monkey comes from, ya gotta be a monkey to get at all the grease fittings on a rig. This was the early to mid 70's so unsure if they are still the same. Back then all the tires except the steers had split rims and I fixed lots of fixed rim flats.
  4. beastr123
    beastr123 Road Train Member
    2,951
    24,205
    Jan 2, 2014
    Moose Jaw SK CAN
    If your air control is set on defrost your A/C is on to reduce moisture on the windshield.
    Or check that the bunk control is not set to A/C and over-riding the drivers controls.
    QUALITYTRUCK and Rideandrepair Thank this.
  5. earnies2
    691
    281
    May 17, 2012
    Dedham, MA.
    Thanks the controls wer not set on defrost.. but I didn't check the bunk.
  6. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Turn your cab and bunk blowers off. If the ac is still running, then the compressor is getting 12 volts all the time from either a faulty body controller or someone has done some rewiring. Since the ac is controlled ultimately by the body controller, the only way to really see what is going on is to use Diamond logic software to diagnose this.
    earnies2 and QUALITYTRUCK Thank this.
  7. earnies2
    691
    281
    May 17, 2012
    Dedham, MA.
    Thanks you're the best . And rite as always this morning I hopped in the bunk and turned the bunk off and all is well....I feel like an ### ,and I'm a mechanic.......
    Heavyd and God prefers Diesels Thank this.
  8. God prefers Diesels
    4,198
    22,265
    Jun 26, 2020
    South Texas
    My uncle rewired a car once. Couldn't get it to start. Tore apart the dash several times. Nothing wrong. Mom got in and started the car.
    He wasn't pushing in the clutch.
    Sometimes as a mechanic, you can't see the forest for the trees.
    Deere hunter, Heavyd and earnies2 Thank this.
