So I'm trying to learn what I can about tankers. I was looking at the fuel tankers themselves, and most seem to have capacity of 9200 or 9500. I'm trying to get the weights to make sense. (I've searched but cannot find the answers)
1/ how much fuel do you usually haul? By my calculations filling a 9200 would put a guy way overweight.
2/ how heavy is an empty tanker - typically?
3/ how heavy do companies want your truck to be max to do long haul tank driving?
thanks, bergy
A couple simple tanker questions...
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by bergy, Jul 10, 2014.
Page 1 of 3
Gasoline is 6.8 # per gal. #2 oil / Diesel is 7.5. You can do the math from there.
1- Depending on the equipt. 8600-9200 of Gas, 7500 #2/Diesel. Assuming you are asking about fuel.
2- An empty rig is about 15,000 #
3- Long haul tank is not hauling fuels. Different products have diff. Weights. All depends on weight per gal. how much you load.Skydivedavec, bergy and Cowboy007 Thank this. -
Thank you Slant6 for the information. The one thing I am sure of is that I want OTR. From what you say, I'll be pulling a tanker of something other than fuel.
Exactly.
Fuels are typically shift work, slip seat trucks. Usually within 50-75 mi. of point of loading. 4 loads per shift. Sometimes more, sometimes less. Generally about 250 miles per shift.
Keep in mind this all depends on the company.
OTR is a whole different ballgame.bergy and Skydivedavec Thank this. -
That's good information. I'll leave the local stuff with multiple drops for those that want to have a home base. I think I'm suited better to long runs, as home time isn't on my priority list.
While he's asking about tankers, answer this for me. In coastal states the fuel terminals get thier fuel via tanker from the refineries correct? How about inland states like Kansas? Pipeline?
Pipeline. Most all, coastal and inland are connected to pipeline.
FYI. gas work is clean, easy work.bergy and Skydivedavec Thank this.
Tankers, do you want to haul food grade product, waste product, chemicals? already ruled out gasoline, diesel, crude oil.bergy and Skydivedavec Thank this.
TLeaHeart
I don't know the answer to that yet. I'd been thinking I was going to pull a step, but the tanker thing kept popping up as a better fit - Chinatown has continued to draw me towards tanker with many of his posts, so you can blame him that I've invaded your fine corner of TTR.
Since I want to do OTR, and fuel and crude is off the table, I'll continue with my research. I'm open to any type of tanker - chemicals, dry bulk - Any suggestions would be welcomed.
I'm not a prima donna, and will serve my time as a newbie, but if I could have my choice I'd prefer to work mostly in the south, as an eventual goal.
I am fortunate in that I'm able to purchase my own equipment, and would like to purchase and lease on to a carrier as soon as that would be prudent. People say be a company driver for a year or two and I'm ok with that. I'm a little concerned that I've heard some companies have weight limits on OO trailers (although I have not heard the weight). Since I'm going to be living out of my truck, will this weight limit be overly restrictive?
bergy
Page 1 of 3
