A different jake problem
Discussion in 'Volvo Forum' started by majestyk, Sep 2, 2013.
  1. majestyk
    majestyk Road Train Member
    1,658
    885
    Jun 28, 2009
    las vegas, nv
    Just started today. When the jake comes on hearing a loud banshee type whine from under the hood. Thanks for the insights.
  3. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    some trucks have been programmed that when the jake is fully engaged it also engages the fan hub, so there is even more drag on the engine to slow you down.
  4. 07shaker
    07shaker Light Load Member
    200
    727
    Jan 12, 2013
    Tx
    What year and engine? If its like my Detroit the way I understand when the jakes come on the turbo puts back pressure on the engine as well. If you have a gasket leaking on your manifold that could be causing the noise. I've seen that happen on a Dodge with the 6.7 cummins; actually a fairly common problem. Its very annoying though. Hope you can find a solution.
  5. majestyk
    1,658
    885
    Jun 28, 2009
    las vegas, nv
    Thanks guys. It is an 06 with a Volvo engine.
  6. Damage
    Damage Light Load Member
    67
    17
    Jan 13, 2012
    Newark, Nj
    You likely have an exhaust leak. Its either between the EPG housing and turbo, or turbo and manifold, or lastly manifold and head. Most of the ones we have worked on it was leaking between the turbo and manifold.
  7. majestyk
    1,658
    885
    Jun 28, 2009
    las vegas, nv
    Thanks Damage. I have been able to smell a little exhaust when idling for a while but nothing too severe, I suppose it has just gotten worse in the last few days.
