A headache rack installation with espar
Discussion in 'Flatbed Trucking Forum' started by badvik_83, Apr 4, 2023.
  1. badvik_83
    badvik_83 Light Load Member
    76
    136
    Mar 11, 2023
    Just switched to a flatbed trailer and was willing to get a headache rack. But I have an accu bunk heater and there is no space for u bolts on one of the sides. Yet I see trucks with the system and rack installed. Can someone share how did you fasten it? Was looking for flat u bolts or something but just didn't come to a solution
  3. badvik_83
    76
    136
    Mar 11, 2023
    It turns out to be not espar but dual hvac. Regardless, it has a battery in the frame
  4. D.Tibbitt
    157,057
    Can you post some pictures?
    cke, flood and Cattleman84 Thank this.
  5. badvik_83
    76
    136
    Mar 11, 2023
    D.Tibbitt Thanks this.
  6. badvik_83
    76
    136
    Mar 11, 2023
  7. D.Tibbitt
    157,057
    Hmmm so im guessing that espar system is in the way? Is it possible you could relocate it? This is how my headache rack is mounted. The bottom support beams of the rack sit on top of 1inch thick rubber/nylon pads then large ubolts with a flat piece bolt it to the frame.. U should be able to look around online and find some headache rack mounting kits
    NoBigHurry and cke Thank this.
  8. MacLean
    MacLean Road Train Member
    1,380
    4,090
    Sep 12, 2017
    Why 1” thick? I’ve only ever seen / used half that of less.
  9. skallagrime
    skallagrime Road Train Member
    3,855
    9,927
    Apr 10, 2012
    Indiana
    Agreed, more than that, if at all possible keep the bolt end DOWN, too easy to catch your foot on the protruding end
    Guess it could be he only had a short socket, so a 1 inch pad made install easier (looks like 2 1/2" pads)
    Did mine with a single 3/8 pad yesterday, but put a small one between ubolt and aluminum as well
  10. skallagrime
    3,855
    9,927
    Apr 10, 2012
    Indiana
    Some more wider angle shots to get a better idea of things would be ideal, maybe chalk mark or mark on a peice of wood the possible range of the ubolt locations.
    What i see is that one side usually will have one ubolt that is a pain no matter what you do
    cke and D.Tibbitt Thank this.
  11. D.Tibbitt
    157,057
    What does it matter how thick it is? The guy is trying to figure out how to mount a headache rack. In every thread there is people that add nothing to it
    singlescrewshaker, cke and flood Thank this.
