a mirror mount for 2014 freightliner
Discussion in 'CB Radio Forum' started by TruckerPete1990, May 18, 2013.
  1. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,383
    Jul 16, 2012
    Bentonville Arkansas
    So om gonna be moving into a 2014 freight shaker.. I seen some time of mount that you just unscrew ur bottom mirror bolts put it on there and tighten boltsup. Then put your antenna on it.. its alrdyed angled anyone know what I'm talkin about
  3. topcat1974
    topcat1974 Light Load Member
    119
    31
    Sep 12, 2010
    Charlotte, NC
    What kinda freightliner is it???
    Sent from my LG-P769 using Tapatalk 2
  4. TruckerPete1990
    8,623
    5,383
    Jul 16, 2012
  5. topcat1974
    119
    31
    Sep 12, 2010
    Charlotte, NC
    Stargun antennas make great mounts
  6. jbee
    jbee Medium Load Member
    664
    619
    Jun 3, 2011
    NC
    If you plan on mounting an antenna with any kind of weight, do not use the single shaft mount.
    There are 2 other versions that use both the top and bottom screws. One uses a shaft for a "Clamp" style mount and the other uses the base mount style. These can be used on either side of the truck or both sides.
    Just Google Cascadia mounting bracket.
    TruckerPete1990 Thanks this.
