A question in two parts...
Discussion in 'CB Radio Forum' started by Broke Down 69, Nov 26, 2016.
  1. Broke Down 69
    Broke Down 69 Road Train Member
    2,733
    9,772
    Jul 3, 2016
    Concord NC
    First, I'm about to change companies and move from KW 700s and 680s to a Freightliner Coronado '15 or '16 model, not sure which yet. I'm aware that the Cascadia has a lot of issues with where and how to mount the antennas and was wondering if this crosses over to the Coronado as well.
    Second, I bought a Bearcat 880 from a driver giving up the job for $40. In his truck the SWR was around 1.2 (internal meter) but when I put it in mine it jumped to 2.1. We were running identical antenna setups but he was in a '16 T680 and I was in a '13 T700. I figure that the problem was older coax that may not have been in the best shape so I didn't worry much about it as I could still get out a couple miles and knew that I couldn't do anything about the cable, company wouldn't let me.
    Heading to a newer truck I think cable condition will be less of an issue and was wondering if an 880 was really worth tuning and if it was could I get a tuning "recipe" from you more knowledgeable users than me. I know how to turn it on and talk but that's about it.
  3. Ougigoug
    Ougigoug Heavy Load Member
    971
    824
    Dec 4, 2012
    Planet earth
    Can't tell you if the radio is worthy of any money investments but one that i can tell you is do not trust any internal SWR reading.
    Get a real meter instead.
    Good luck!
    Broke Down 69 Thanks this.
  4. Ridgeline
    22,727
    123,501
    A year or two won't make much of a difference with the life of the coax.
    What may be the issue is your antenna.
    Broke Down 69 and rabbiporkchop Thank this.
  5. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    Ignore spending money on tune ups for the radio.
    Focus on perfecting the antenna system on the truck.
  6. Broke Down 69
    2,733
    9,772
    Jul 3, 2016
    Concord NC
    That was sort of the point of the first part of the post...whether or not the Coronado had the same issues with the antenna as the Cascadia. With this truck, I'll be free to do whatever I want with the cable/antenna equation and I'm not adverse to spending the money required to get the best of both.
    With respect to tuning, I was really just curious if a starter radio like the 880 was even worth it or whether it might be time to think of buying a next step up radio. Maybe a Cobra 29 or the like.
    I'm not interested in having some massive wattage setup to talk to Mars with but it'd be nice to get out a little further than I am right now.
  7. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    In regards to tuning the radio, 95% of the time, the costs outweigh the benefits (if there are any)
    I'm a firm believer in focusing 95% of your attention to the vehicle itself and the antenna system before considering radio modifications.
    Unless you can consistently reach out 15 miles with a stock radio, the antenna system has issues that would render a bigger radio a waste of money.
  8. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    The difference between those 2 radios won't be noticed by the person you are speaking to, and I've never driven a Coronado, but I suspect It is a better truck to transmit from.
  9. volvo244t
    volvo244t Road Train Member
    1,775
    1,779
    Jun 24, 2010
    Bettendorf, IA
    A Coronado is just a Century with a long, square hood, a set-forward, air-ride (sometimes?) front axle, and a tarted up interior.
  10. Broke Down 69
    2,733
    9,772
    Jul 3, 2016
    Concord NC
    Yes, I know.
  11. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Dont need a big radio to reach out,its your ant that does the bulk of the work....
    Its like sayin i got 500 hp engine but i dont have tires on the rim but my other truck has 350 hp and has tall 24.5 tires..
