Abs code and sensor question.
Discussion in 'Volvo Forum' started by Socal Xpress, Jun 7, 2017.
  1. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    I have an Abs code mid 136 sid 1 fmi 1
    Left steer axle sensor looks to be going bad.
    Are the front sensors the same as the rear sensors? I always have a spare with me but never had to replace a front and wondering if they are interchangeable.
    @nasriza @benrab @QUALITYTRUCK
    Thanks
  3. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    Check wires from sensor and bearing. If bearing is lose it can give false code.
    Socal Xpress Thanks this.
  4. nasriza
    nasriza Road Train Member
    2,409
    2,078
    Feb 1, 2013
    Chicago, IL
    no front sensor are 90 degree ususally as far as connection wise goes yes they are the same electronicaly not physicaly.
    Johny41, QUALITYTRUCK and Socal Xpress Thank this.
  5. QUALITYTRUCK
    1,819
    1,784
    Jun 14, 2009
    romulus,mi
    Nasriza is correct again. Just check 2 things first. Make sure that it is pushed in all of the way. You can unplug and test with VOM meter. Should read between 1000-1200 ohms if good. The steers are easy to replace by grabbing with pliers, twisting and pulling out.
  6. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    Outer bearing was on its last legs. I was able to make it home to get it replaced.
    BUMBACLADWAR and Snailexpress Thank this.
  7. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    First of all
    FMI 1 - weak signal. Check sensor ajustment. Try to nock it slignhlly to reduce air gap,
    SID 1 - front axle #1, left wheel., not the drive axle)))
    Good luck!)
  8. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    First of all
    Good luck!)
