ABS help, 2013 peterbilt 388
Discussion in 'Peterbilt Forum' started by cgsnipe, Jul 30, 2018.
  1. cgsnipe
    cgsnipe Bobtail Member
    34
    13
    Aug 26, 2012
    Alvin, TX
    I purchased a 2013 peterbilt 388 from TMC. So far the truck has been great except for one thing. TMC for some reason wired the ABS through the yellow auxiliary pigtail and the dump valve switch through the center pin on the main pigtail wire. Is there an easy way to switch this back? I've been under the truck looking for a place to access the wires without cutting everything open. I'm sure they had to have switched them some place simple but i can't find it. any ideas would be greatly appreciated.
  3. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    The 7-way should go to the firewall plug, there should be a decal next to it that says, "Hood, Trailer, Spare, Chassis." You'll have a plastic cover held on by 3 screws. Pull that off an look in there. If no signs off messing with it there, I'd disconnect it and ohm out the 7 way cable from the fire wall to the trailer plug. That will tell you if that's still intact or spliced somewhere along the frame. If that's all intact and wired as OEM, then they did it under the dash.
    cgsnipe and QUALITYTRUCK Thank this.
  4. cgsnipe
    34
    13
    Aug 26, 2012
    Alvin, TX
    Do you have a picture of that connection on the fire wall?
  5. pushbroom
    pushbroom Road Train Member
    1,791
    7,403
    Sep 1, 2012
    That connection is the style on the previous 388s. A 2013 388 should have a chassis node on it. Some of the trailer wiring comes out the chassis node, some comes out the lower rectangle plug on the firewall.
    If you follow the trailer cords back there should be round plugs mounted under the sleeper/cab that they mount to. Might be able to switch the wiring at them. Last 6 of s/n for better info
    spsauerland and cgsnipe Thank this.
  6. cgsnipe
    34
    13
    Aug 26, 2012
    Alvin, TX
    Last six is 202204. I appreciate the help. I don't know why they would wore these things this way. I thought the abs had to be wired to the center pin on the main pigtail.
  7. pushbroom
    1,791
    7,403
    Sep 1, 2012
    Wiring diagram attached. Looks like pins u and t will need to be switched.
  8. pushbroom
    1,791
    7,403
    Sep 1, 2012
    Forgot to attach
    cgsnipe Thanks this.
  9. cgsnipe
    34
    13
    Aug 26, 2012
    Alvin, TX
    I have looked all over the fire wall and can't find that plug or the wiring harness 92-8471. If I do find them, will it be as simple as moving the pins in the plug?
  10. pushbroom
    1,791
    7,403
    Sep 1, 2012
    It will be located in the frame rail under the sleeper/ cab. Follow the trailer cords back from the socket
    spsauerland Thanks this.
