ABS light on and off
Discussion in 'Trucks [ Eighteen Wheelers ]' started by tibois, Apr 15, 2015.
  1. tibois
    tibois Bobtail Member
    25
    4
    Nov 1, 2012
    Last week my abs light on the dashboard and the trailer started coming on and going off at times, but mostly staying on now. I realize when the pigtail is disconnected, the dash light goes off, which tells me that the problem is likely to be in the trailer. I have a 2007 dry van Great Dane and 2015 Cascadia Evolution. Any ideas on what I can check or fix before headed to the shop?
    Thanks,
    tibois
  3. Vio
    Vio Light Load Member
    150
    67
    Sep 25, 2012
    AZ
    Abs sensors on trailer.
  4. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    When you key on, does the light come on for a few seconds, then go out? The first thing to do is wiggle the pigtail and see if you can get the light to flash, it might just be a bad connection. Check for god power at the center pin (Aux). If you have a problem at the center pin, you will get the ABS light coming on every time you step on the brakes, the ABS gets power from the brake lights if there isn't power at the center pin.
    Do you know what kind of system it is? Wabco, Bendix, Haldex?
  5. tibois
    25
    4
    Nov 1, 2012
    Do the wheels must come off in order to check or change it? I have no idea of its location.
    Roadrunner 16 Thanks this.
  6. GrapeApe
    2,215
    2,212
    Jan 7, 2013
    What are you trying to check or change? Don't change anything until you diagnose the problem unless you just want to waste money. Identify the system, if you don't know take a picture of it and post it. Follow the service brake hoses from the brake chambers to the relay/abs valve to find it. Once you know what kind of system it is, I can probably help you get the flash codes and get you in the right direction. Anything you do without knowing what fault it has is a guess.
    In an extreme case, an intermittent signal or large sensor gap fault could be a loose or bad wheel bearing, so do not let this go too long.
  7. EHB
    EHB Medium Load Member
    491
    209
    Apr 26, 2011
    Newfoundland
    Differently check for wire connections and for corrosion at them connections. Including grounding wire problems.
    If the wiring code on the truck and trailer match.
    Check computer with a code reader and see what comes up.
    It may or may not be an ABS problem.
    Assuming the dash wiring code is correctly installed from the factory.
  8. tibois
    25
    4
    Nov 1, 2012
    OK GrapeApe, thanks already for your consideration. The system is Bendix; a picture is included.
  9. guyhoon
    guyhoon Bobtail Member
    Wait, differently?
  10. 2chevaux
    2chevaux Bobtail Member
    HOW TO CHECK THE CENTER POWER?
  11. 2chevaux
    Could you please tell how to test the center pin?
