Abs light on on trailer only.
Discussion in 'Ask An Owner Operator' started by Joebeaufort, Sep 24, 2021.
  1. Joebeaufort
    Joebeaufort Bobtail Member
    My abs light is on on my trailer, but not on dashboard. Shop took off all wheels and cleaned and adjusted the sensors, said it should go off after hitting higher speeds. It hasn't. Any thoughts?
  3. JoeTruck
    JoeTruck Heavy Load Member
    853
    3,393
    Mar 13, 2015
    LOWER 48
  4. Rideandrepair
    17,580
    56,946
    Aug 8, 2015
    Probably a wire to one of the sensors. I hope it was a Company Shop, and you didn’t have to pay them. They should have diagnosed which wheel it was, and fixed the one wheel, sensor, wire, or whatever. Depending on which way the ecu is mounted. Blink codes will tell which one is the problem. Try turning key on, off, on, off, and on again. Count the blinks. Look underneath above the axles. Find the ecu. Note how many wires are plugged into it. 2 or 4. Also note if wires are plugged in from front side ( towards front on trailer) or plugged in from the back ( rear ) of trailer. Depending which way the ecu’s mounted will determine which side the blink codes referring to.
    D.Tibbitt and BigBob410 Thank this.
  5. Rideandrepair
    17,580
    56,946
    Aug 8, 2015
  6. Rideandrepair
    17,580
    56,946
    Aug 8, 2015
    1E4746BF-D3C1-4DEC-B883-4C4A3F798EB1.png My mistake. Here’s the procedure for getting blink codes.
    D.Tibbitt Thanks this.
  7. 201
    201 Road Train Member
    12,840
    26,433
    Apr 16, 2014
    high plains colorado
    It's called A-"BS" light, for a reason.
