ABS PROBLEM!!
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Perchie15, Jul 16, 2022.
  1. Perchie15
    Perchie15 Light Load Member
    247
    71
    Aug 16, 2021
    Hello y’all. I have 6ABs codes it’s a Cummins IXS ENGINE 2020 kenworth t800, but u scroll through the settings and it says has 6 faults, but I hooked up our scanner that has haldex, wabco, bendix brake program trials. And it isn’t picking anything up for codes I can’t even scan the trucks ABS! Most important when you turn the key, it doesn’t do the click checking. What’s wrong here I did check all the fuses/relays all are good!!
  3. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    maybe those codes are from a past episode, and they were never cleared?
  4. Perchie15
    247
    71
    Aug 16, 2021
    Could be but How would one clear them when they spit show up on the laptop?
  5. Goodysnap
    Goodysnap Road Train Member
    3,769
    9,190
    Jul 12, 2017
    Most often with no Chuff test the ABS module is not awake. If you can’t talk to the module this may be the issue. Start with fuses. Then check powers and grounds to the ABS module.
    spsauerland, AModelCat and biopure22 Thank this.
  6. wichris
    wichris Road Train Member
    4,474
    9,217
    Jan 17, 2011
    Insite
  7. Perchie15
    247
    71
    Aug 16, 2021
    but when none of the abs does the chuff test it wouldn’t be the module would it? Cuz there is 3 on this truck one for each set of wheels.
  8. Goodysnap
    3,769
    9,190
    Jul 12, 2017
    ABS ECU…..
    Not modulators.
    yes there are 6 modulator valves.
    AModelCat and Perchie15 Thank this.
  9. Perchie15
    247
    71
    Aug 16, 2021
    Oh duh. Where
    Ohhhhh yessss duh huh. Something being weird there.
  10. Goodysnap
    3,769
    9,190
    Jul 12, 2017
    ABS ECU should be bottom center lower of dash.
  11. AModelCat
    164,212
    I'd be following Goodysnap's advice. If you can't "see" a module, usually its not powering up or its somehow been disconnected from the datalink.
    Magoo1968 and Perchie15 Thank this.
