ABS valve leaking air
Discussion in 'Peterbilt Forum' started by Loaderlou, Feb 22, 2019.
Page 2 of 2
Did it work?Another Canadian driver Thanks this.
Where can I find the quick release Albee that go in to the unit? Do I have to buy a whole new regulator?
Another Canadian driver Thanks this. -
I guess my other question would be. Is it normal for it to purge a few times after I shut down the truck. It’s purging from the T fitting quick connect.
I'm having the same issue but I pinche d off all 4 lines and the leak still exists. Could it be the valve itself?
Hi ya all need some help guys i was doing brake adjustment yesterday on my freightliner 99 when you you tapping brake pedal abs brake air valve leaking air under the 5 th wheel is that bad abs brake valve or something else thanks
I’m having the same issue, my abs valve it’s leaking. I replaced it after checking all my chambers and still leaking. Help!!
I’m having a similar problem. I changed out the the two long stroke brake chambers. But air still come out the abs port.
Page 2 of 2
