ABS warning light for truck.
Discussion in 'Freightliner Forum' started by xsetra, Mar 20, 2017.
  1. xsetra
    xsetra Road Train Member
    5,198
    7,150
    Aug 21, 2011
    99 freightliner. FLD 120. Wabco system. Truck abs warning light stays on in dash.
    I found the abs computer behind the passenger seat under the bunk. I have pushed the test button and the dash light blinks twice repeatedly.
    I had a mechanic look at it. They determined the ECU was receiving only 2 of the 3 required ignition power sources.
    He said the pin was in the terminal connection closest to the center of cab. He said the center row of pins the 3rd and 4th pins, one should be a ground and the other a power.
    They didn't have any more time to look at my truck.
    Thanks for any help.
  3. Hulld
    Hulld Road Train Member
    2,884
    6,568
    Oct 19, 2015
    Upstate NY
    What happens if you run a new switched power to the pin that was missing it ?
  4. Renegade44
    Renegade44 Bobtail Member
    It's probably just a bad sensor. One for each wheel located behind the hub. They just push in until they make contact and plug up.
  5. xsetra
    5,198
    7,150
    Aug 21, 2011
    I'm not sure which one to power. I don't want to fry the computer.
  6. austinmike
    140,820
    I wouldnt worry about it. The abs light comes on and goes off at random on my 2010.
  7. xsetra
    5,198
    7,150
    Aug 21, 2011
    The tech said the laptop determined it was an ignition power not powering up when ignition switch is turned on.
    Don't the tires and drums need to be removed to replace sensors.
  8. xsetra
    5,198
    7,150
    Aug 21, 2011
    Other than the Washington DOT wrote me a warning on an inspection. I kinda have to fix it.
    I wasn't worried about it for 6 years. Even had an inspection and truck was cvsa stickered.
    I wish all inspections were the same.
    No problems with my brakes working.
    They don't lock up on hard braking. Well the hand full of times I did.
  9. xsetra
    5,198
    7,150
    Aug 21, 2011
    To close this thread. The problem was a (previous) lazy tech decided to test power in wires by piercing the insulation with his test probe.
    This happened before I owned the truck.
    Several wires corroded internally. They had to be replaced.
    This tech said 15 breaks in about a foot of harness.
    QUALITYTRUCK Thanks this.
