Ac blower cutting out
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by EWV, Oct 5, 2019.
  1. EWV
    EWV Light Load Member
    80
    27
    Mar 22, 2016
    Hi i have a 2006 w900l kw.
    My hvac system works well but has recently started to cut out / stop blowing for a couple seconds then starts blowing again on its own. Sometimes it cuts out andon again continually for 5 or 10mins then is ok again.
    It does it on warm air / cold air / ac on or off ....blower setting 1 2 or 3.
    Any ideas the best thing to check 1st?
    I will get the freon level checked when i get back home but it was only done a couple months ago when a new line was installed and has worked fine up until the last week or so. And i cant see any leaks anywhere
    Thanks
  3. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    Inspect wiring connectors at the blower and the control switch. If you find melted pins repair or place both pieces along with the blower itself. The motor is drawing excess current.
    The other place to check is the 30 amp breaker going open. Check amp draw or swap the breaker for known good and see if it still trips.
    spsauerland, Working2party and EWV Thank this.
  4. DUNE-T
    DUNE-T Road Train Member
    7,046
    17,160
    May 10, 2015
    Detroit, MI
    On my truck it was just the blower itself going bad
    EWV Thanks this.
  5. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    Freon has absolutely nothing to do with the blower motor.
    The heater uses the same blower motor.
    As mentioned. Check circuit breaker. Wiring. Motor connection. Maybe it's a loose connection when you hit a bump. And blower motor.
    EWV Thanks this.
  6. Robert Stoddard
    Robert Stoddard Bobtail Member
    11
    Oct 6, 2019
    New to this form trying to get some information have a 2019 western star replace the resistor on the AC blower vehicle runs fine for a couple hours cause it before sound like there was a knocking on the dash make sure there is no debris or anything no the vehicle is doing the same thing vehicle AC motor runs freely with no signs of damage could this be Could this be the AC motor
    Short Fuse EOD Thanks this.
  7. Short Fuse EOD
    2,791
    8,760
    Jul 29, 2015
    Midwest
    I would check the relay for the blower motor. Replace with a good one and Keep it on the low setting. Place your hand on top the blower motor and feel if it is hot. keep it on the low setting. You can do the same for the one upfront or the bunk. Place your hand on top the blower motor and fuel if it is hot . Could be tripping the relay.
    EWV Thanks this.
  8. Robert Stoddard
    11
    Oct 6, 2019
    Question so is making a knocking sound And the resister has been replaced there’s only one blower motor I don’t think there’s another one there’s one on the right hand side underneath the passenger seat the relays located in the fuse box correct? I’m new at working on this type of equipment just trying to figure out a couple of the tricks thank you for the quick response I appreciate it.
  9. Short Fuse EOD
    2,791
    8,760
    Jul 29, 2015
    Midwest
    Mine is currently doing the same thing. If you have a bunk with thence you have to blower motors on that K dub. If not you just have the one at the passenger area. If the K dub it’s like a Pete The front blower relay should be left of your left boot in the Fuse Panal?
  10. Robert Stoddard
    11
    Oct 6, 2019
    Tomorrow can I message you a picture of the both relays because once I pull the motor out under the passenger seat all I see is the blower motor and resistor and there’s a fuse box on the top if you realize but I’m not sure about
  11. Short Fuse EOD
    2,791
    8,760
    Jul 29, 2015
    Midwest
    Hey I was with 1/6 in 08 Helmand.
    8590 Thanks this.
