AC clutch doesn't engage.
Discussion in 'Ask An Owner Operator' started by Kruse Family Farms, May 31, 2024.
  1. Kruse Family Farms
    Kruse Family Farms Light Load Member
    295
    319
    Dec 6, 2022
    Hey guys I am a bit confused on this one. 2001 Freightliner classic xl. I fully replaced my AC a year or two ago. New everything. Has worked flawless since. This year I go to turn it on and the clutch won't engage. The magnet behind the clutch is getting 12v but doesn't magnetize? I have tried two different magnets and clutches. Both don't have that many miles on them? If that magnet has 12vs shouldn't it magnetize and draw the clutch in?? What am I missing here?
  3. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    You need power and ground to make the clutch work. I could be wrong but I think ground goes through sensors before actually reaching ground.
    Now here's the thing.
    You all do this and I have no idea why.
    FIRST. Make sure you have at least 50 psi. Otherwise clutch won't engage. The low pressure isn't completing the ground.
    If you got too much freon. The high pressure will stop it from working.
    Second would be electrical.
    I'm betting you're out of freon. Which means a leak. And causing the electrical to not function.
    Rideandrepair and Concorde Thank this.
  4. Big Road Skateboard
    7,174
    40,655
    May 2, 2021
  5. Concorde
    Concorde Road Train Member
    5,502
    19,566
    Jun 29, 2016
    West Melbourne Florida
    If your Freon is low that’ll cause it to not engage. Probably want to have it evacuated and weighed..
    I went through the same problem and low Freon was the problem. Started out with a condenser leak and one thing led to another
    Rideandrepair Thanks this.
  6. Big Road Skateboard
    7,174
    40,655
    May 2, 2021
    Freightliner used power to activate, instead of ground, at least at that time. So 12V at the clutch (assuming no wiring has been done) would mean power has gone from the dash control, through the thermostatic switch, and through the low and high pressure switches, to the clutch.
    So either a ground issue, or a damaged 12V supply that can't carry the load
  7. snowwy
    20,612
    13,333
    Jul 6, 2009
    So you could use a ground wire connection and see if the clutch engages. You don't need the motor running.
    You could also test for power at the ground wire coming out of the clutch. Unless it's one wire and the compressor itself is grounded.
    I'd still check the freon though.
  8. Lazer
    Lazer Road Train Member
    1,850
    2,983
    Jan 22, 2017
    Is this the first you’ve used the truck this year? It’s almost June. One would have thought the ac was in use months ago.
    One test to do, turn on the ignition, but don’t start. Turn on the hvac blower(low setting is fine) now press the button that turns on the ac, if everything is good you should hear the click of the ac clutch. Turn the air control to defrost, you also hear the ac clutch click. The ac compressor activates when using the defrost in modern trucks.
    If no clicking sound from the ac clutch, you have an issue, could be electrical, sensor, control switch, low refrigerant, etc.
  9. Kruse Family Farms
    295
    319
    Dec 6, 2022
    I believe I might have a grounding issue. Power makes it all the way to the magnet. I also bypassed all the switches and it made no difference. High and low switch appear to be working. There is definitely freon in the system. And yes I have known it is broken for a few months now but just had the windows down when I was hot until I had some more time to look things over. I initially thought it was a wiring issue. I am now thinking the original magnet maybe went bad? Going to go out and mess with the ground and see what happens. Thanks for all the suggestions!
  10. snowwy
    20,612
    13,333
    Jul 6, 2009
    Is there ENOUGH freon?
    Anything less then 50 won't trigger it.
  11. Kruse Family Farms
    295
    319
    Dec 6, 2022
    Yeah freon isn't the issue. If there was to low or to high of freon it wouldn't even send power to the magnet to begin with. Jumpered each sensor separately as well just to be sure. Also freon pressure was the first thing I checked back when I originally looked over the system. Was all good. My first assumption was also that it leaked out.
