AC compressor engages but no cool air.
Discussion in 'Ask An Owner Operator' started by Forever237, Sep 24, 2024.
  1. Forever237
    Forever237 Light Load Member
    122
    63
    May 29, 2016
    Hello, Good Ol’ folks
    AC compressor is engaging but the low pressure side is not budging. I don’t have tools to measure both side. Only a can with a gauge that recharges.
    Low pressure is in 70 to 80 psi with truck off.
    With truck on, i checked the compressor and it clutch engage but “low pressure” side is not lowering the pressure.
    what should I look for?
    Trying to save money
  3. dosgatos
    dosgatos Medium Load Member
    609
    1,313
    Sep 18, 2012
    The best way to know if you have the correct amount of refrigerant is to evacuate the system, pull a vacuum for the proper amount of time and then recharge with the specified amount for your truck. You can show adequate pressure and still not have enough refrigerant in the system. Also can have too much refrigerant and the pressure will show the same.
    If you know you have the correct amount the the pump still doesn't pull the low side down, the pump is bad.
    I've been through it enough times I carry a gauge set, fittings, spare expansion valve, drier and a vacuum pump I can run off the inverter. Every few years I'm out on the road and something happens. Glad to not rely on a truck stop.
    At least it's getting to cooler weather.:)
  4. abyliks
    abyliks Road Train Member
    4,150
    9,789
    May 2, 2010
    ludlow MA
    Harbor freight sells a guage kit for cheap, check your pressures, is the suction line cool, the same, or hotter then everything else? Could be the compressor itself if everything else checks out
    Rideandrepair and Forever237 Thank this.
  5. Diesel Dave
    9,744
    33,388
    Jan 20, 2010
    Hesperia, Ca.
    Sounds like the expansion valve. Needs to be replaced. Evacuated then charge again.
  6. Forever237
    122
    63
    May 29, 2016
    thanks for reply.
    Got it. I guess I’ll have to evacuate and recharge to proper amount and see.
    Do You know how much freon it takes, like ballpark?
    Rideandrepair Thanks this.
  7. Lazer
    Lazer Road Train Member
    1,850
    2,983
    Jan 22, 2017
    Just for curiosity, what make and model is the truck?
  8. Rideandrepair
    17,576
    56,940
    Aug 8, 2015
    Should have a sticker somewhere. Most Freightliners take 3 lb 7oz. I always use 5 12oz. cans. Total 60oz. That’s 5 extra oz. I bleed the air from the line on each can before using. Always works just right. Good time to add some green ultraviolet dye. Available already mixed in a can refrigerant. One or two cans with it should be plenty. Better to buy a set of gauges. Get a small bottle, add it in through the hose. YouTuber “Chris Fix” has some great videos on A/C. Very thorough simply presented info.
    loudtom and Forever237 Thank this.
  9. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    I don't recommend the harbor freight gauges. They screw in far enough to bend the Schrader valves.
    If you do decide to go that route. Only open them enough to get pressure readings. And slightly further. Don't open them all the way.
    Different trucks take different amounts. Look around on the firewall or dryer. There should be a label that says what to use and how much it holds. Hopefully the label is still there and readable.
    The low pressure switch requires 50 psi to kick the compressor on. A fully charged system will read around 120 psi depending on where you're at. That's in the dead of heat. Down by the southern border it's probably closer to 130 psi. The northern border probably around 100 psi.
    Freon contracts in the cold and expands in the heat. So pressures will be different at different temps.
    Your problem with measuring is you don't have a scale. You'll have to guess best the last can. I don't have a machine but I use 30 pound cylinders with a scale that measures ounces and pounds. I'm not a big fan of cans. I'm also certified so I can buy any quantity above 2 pounds.
    The good news is freon has dropped in price. About 40% for me. It shouldn't cost so much to have a shop do the job. So you know it's done right. The bad news is they'll recycle the freon. Used recycle doesn't work anywhere as good as virgin freon.
  10. Antinomian
    Antinomian Road Train Member
    2,181
    3,476
    Feb 17, 2013
    Yep. Some lessons you have to pay for and that was one for me.
    Rideandrepair and snowwy Thank this.
  11. Forever237
    122
    63
    May 29, 2016
    2016 Cascadia DD13
