Ac/heater temp no power
Discussion in 'Experienced Truckers' Advice' started by Maine trucker, Jun 19, 2020.
  1. Maine trucker
    Maine trucker Bobtail Member
    Hey guys wondering if someone could help me I got a 2019 t880 Kenworth was hooking up a new USB port to charge phone and all the sudden my AC went out no lights nothing so I shorted somethingout the diagram like I can't find the fuse or relay on that would anybody happen to know where it would be thank you
  3. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    May be a fuse, or whats called a fuseable link down in around battery box? Not sure though. Other than that may have to search it out. Unless you have a go to person that works on that model or similar .
  4. bad-luck
    bad-luck Road Train Member
    3,438
    6,331
    Nov 16, 2013
    Baltimore, Maryland
    I would check the fuse Box. I don't know where it's located on that truck I'm sure some other people here may be able to help you locat it
  5. Moosetek13
    Moosetek13 Road Train Member
    14,984
    19,036
    Nov 1, 2010
    Burnsville, MN
    So... what? You plugged a 12V USB charger into the 12V socket and your AC went out at the same time?
    Doubtful the two things are related if that is the case.
    A bad charger would only blow the fuse to the 12V socket.
    You didn't mention if the 12V socket or USB device was still working. ?
  6. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    Was you stripping wires ...or just intermittently connecting juice . Maybe fuse under hood. D/S 3rd from the right on Volvo.
    Maine trucker Thanks this.
  7. BUMBACLADWAR
    1,899
    1,923
    Dec 5, 2013
    Not sure on Kenworth fuse.
  8. buzzarddriver
    3,830
    11,563
    Feb 1, 2011
    Dallas, TX
    I think the fuse panel on Kenworths are in the glove box. you have to remove the liner and the fuse box is on the firewall.
  9. Numb
    Numb Crusty Curmudgeon
    4,319
    10,260
    Jan 30, 2012
    Charlotte, N.Carolina
    : T880 Kenworth Driver Academy - Fuse Box & On Board Diagnostics
  10. Ridgeline
    22,724
    123,374
    I am assuming the op actually was wiring up the port, not plugging it in.
    So if this is the case, it may be the body computer and not a fuse.
    BUMBACLADWAR Thanks this.
