AC Leaking
Discussion in 'Volvo Forum' started by Dazed&Confused, Nov 11, 2014.
  1. Dazed&Confused
    Dazed&Confused Bobtail Member
    43
    16
    Nov 1, 2014
    '98 Volvo 610 Cummins M11- If the system is vacuumed down and charged, it only has cold air for 2 weeks, maybe 18 days at best.
    Where are the most likely places for it to be leaking? Doing a little research shows that the rear AC lines fail, is that the most common issue?
    What else do I need to look for? And are the coolant lines available in the aftermarket, or is it a Volvo dealer item?
    Thanks
  3. Ridgeline
    22,727
    123,458
    '98?
    Condenser is one but I would consider changing out the hoses just in case.
  4. skateboardman
    skateboardman Road Train Member
    6,232
    5,706
    Jan 14, 2012
    flatbed heaven
    sometimes a leak will be at the compressor seal, hard to find, and will sometimes pull vacuum and leak when being used.
  5. RSQ20
    RSQ20 Medium Load Member
    Install some UV dye, then after running, check with a black light...
    ... Philip
