Ac only working while driving
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Global254, Jun 19, 2020.
  1. Global254
    Global254 Bobtail Member
    I have a freighter liner century 2007 Detroit engine, and it only blows cold when driving but not on idle and the water gauge goes up with the ac on and idling, can this problem be connected to the engine fan
  3. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    Sounds like two different problems.
    ( following)
    BUMBACLADWAR Thanks this.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,551
    6,641
    Aug 26, 2014
    Does the engine fan come on while idling and the A/C is on?
  5. pavrom
    pavrom Road Train Member
    3,217
    7,419
    Apr 29, 2012
    NE illinois
    Probably fan switch has problem , i think it turns the fan on when needed ... More knowledgeable people should get it , can be high pressure switch as well .
    I had opposite situation when it cools only on idle and not driving .
  6. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    Could be switch or just blower motor bearing going out..Try banging on blower motor case ...while idleing.JMO
  7. Heavyd
    Heavyd Road Train Member
    7,827
    6,276
    Feb 4, 2009
    Like mentioned, when not moving the fan should be coming on to cool down the condenser so the ac works. If the fan is coming on, then you might have a bad condenser with bad cooling fins.
  8. bad-luck
    bad-luck Road Train Member
    3,439
    6,333
    Nov 16, 2013
    Baltimore, Maryland
    Sounds like the fan is not coming on. May be a high pressure ac sensor. The high pressure sensor tells the fan to turn when the ac head pressure gets to high.
    Global254 and Hulld Thank this.
  9. Cantfinditgrindit
    Cantfinditgrindit Bobtail Member
    Jun 28, 2021
    What was the fix for this? I’m having the same problem in a Colombia.
  10. mnmover
    mnmover Road Train Member
    1,237
    1,104
    Apr 5, 2009
    Lichfield MN
    Could be all of the above, but check the volume of air going through the condenser in front of the radiator. does the air keep a cardboard or towel stuck to the front while engine and fan are running? If not, the condenser is plugged up with dirt and debris. Not uncommon. wash, or use air to open up the vanes to allow air to pass through and cool the freon. Perhaps at highway speeds the air gets forced through and the condenser works some, but not when standing still.
  11. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    Old post, engine fan will come on when psi inside gets to high to get rid of latent heat in the system.
    If you have a fan override switch turn it on
    It should cool down.
    Check HVAC filters make sure clean.
    Evaporator drains are clear snd functional
    Be sure evaporator coils are clean behind filters.
    Without being there and not having a set of gauges to look at. I am going to guess and it could be several things
    Over or under charged
    Expansion valve or valves are bad
    They act like a thermostat regulating the flow of Freon thru the system.
    Change drier when you open system for any reason
    haycarter Thanks this.
