AC question??????
Discussion in 'Volvo Forum' started by OPUS 7, Mar 23, 2014.
  1. OPUS 7
    OPUS 7 Road Train Member
    1,124
    1,010
    Aug 13, 2010
    404
    Im in a 2005 and the AC works fine when you first start out.
    After about 30-45 mins. it starts to slowly get warmer.
    On a really hot day it will gradually lose the battle all together,
    and you gotta roll down the windows.
    The blower moter sounds fine,but its not blowing as hard as when
    started,and air isn't cold.
    The shop has looked at it several times,but its hard to tell them
    how its acting,w/o driving the thing for about an hour.
    Im not gonna go another summer roasting in this thing.You can
    turn it off for about 10-15 mins and it works fine,but will fade out
    again.Thanks for any tips :thumbup:
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Try replace the temp. control inside the A/C box 2 screws all it takes, A/c comp. should be turning off an on to keep it from frezz. up and blowing warm like its doing now.
    K9OTR and OPUS 7 Thank this.
  4. K9OTR
    K9OTR Light Load Member
    146
    84
    Sep 1, 2013
    Rochester, NY
    Sounds to me like the condenser is freezing.. Keep in mind I know nothing about the Volvos, just a little bit about AC systems. I could be way off but the fact that you can shut it down for a while and it comes back. makes me think that its freezing the condenser or lines and thawing during the down time.
    OPUS 7 and chalupa Thank this.
  5. speedbuggy84410
    speedbuggy84410 Light Load Member
    115
    65
    Jan 14, 2014
    One of two things, check your cabin air filter it may be clogged. will stop air flow and in turn cause evaporator to freeze up. check refrigerant level. if low will cause evaporator to freeze up which will restrict airflow and do exactly as you have just described.
    OPUS 7 Thanks this.
  6. OPUS 7
    1,124
    1,010
    Aug 13, 2010
    404
    Thank you very much guys! I will check on running down those suggestions,and see if I can stay cool this summer
  7. bjytech
    bjytech Light Load Member
    246
    222
    Nov 9, 2013
    There is also a good chance it could be the freeze switch on the evap core, they can go bad and then it doesn't cycle the A/C compressor off when the evap core gets too cold and results in it freezing up.
    OPUS 7 Thanks this.
