Ac troubles
Discussion in 'Freightliner Forum' started by Batman13, Oct 14, 2020.
  1. Batman13
    Batman13 Light Load Member
    110
    45
    May 20, 2020
    I have a 2014 cascadia..the ac in the front doesn't blow cold air...while runnin it'll blow cool air...but as soon as stopped it starts blowing hot as hell air.! The only thing I know of is the fuses...in the glove compartment..I'm not sure if it's the condenser and I dont wanna buy the part if that's not the problem...does anyone have any other ideas on what could the problem be?? Thanks
  3. mitrucker
    mitrucker Road Train Member
    5,497
    10,376
    Dec 15, 2010
    Lapeer, MI
    Have you tried cleaning the fins on the condenser and air to air cooler?
    Rideandrepair and Batman13 Thank this.
  4. Spyro2112
    Spyro2112 Medium Load Member
    624
    434
    Mar 17, 2018
    Check filters, turn on see if and when clutch turns check plug for compressor, reset it, belt and or tension pulley on and on
    Rideandrepair Thanks this.
  5. JonJon78
    JonJon78 Road Train Member
    7,242
    43,077
    Jul 1, 2018
    Sounds like possibly a blend door is getting stuck?
    Rideandrepair and Snailexpress Thank this.
  6. Batman13
    110
    45
    May 20, 2020
    How do you reset it?
  7. Batman13
    110
    45
    May 20, 2020
    What is that?
  8. JonJon78
    7,242
    43,077
    Jul 1, 2018
    The door that allows airflow controlled by the actuator...
    I had a similar problem that you are having with my peterbilt. The system had to be evacuated, then the entire hvac was removed in order to fix the broken blend doors...
  9. Batman13
    110
    45
    May 20, 2020
    Oh alright..I'll have to try that when I stop..thanks
  10. Spyro2112
    624
    434
    Mar 17, 2018
    U tube Cascadia ac reset
    magoo68 and Rideandrepair Thank this.
  11. Rideandrepair
    17,573
    56,928
    Aug 8, 2015
    First thing to check is the fan operation at idle, with a/c on. Make sure it’s working. If so, chances are the front of the radiator is blocked with dirt and debris. Take condensor off, leaving the lines hooked up. Set it aside, and clean the radiator fins, along with the condenser fins. Use water and air, maybe some brake keen, from the backside first. Be careful not to use too much pressure and bend the fins. Normally when idling the fan pulls air in to cool the condenser, and lower the pressure. If the fins are corroded badly, you may need to use a tiny screwdriver to clean in between them, very time consuming. An inexpensive fin comb will come in handy.
    Batman13 Thanks this.
