Accessing peterbilt 379 fuel line splitter
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Peterbiltoo88, Apr 17, 2020.
  1. Peterbiltoo88
    Peterbiltoo88 Bobtail Member
    4
    Apr 17, 2020
    How should I access the fuel line return flow splitter? Should I remove the front u-joint with the driveshaft attached or should I drop the passenger fuel tank? Thank you. JS Michels.
  3. lester
    2,957
    8,088
    Jan 2, 2012
    NW, Iowa
    You shouldn't have to remove anything. Crawl under and work around the driveshaft.
    This is a daycab but you can see the spliiters there and there's plenty of room to get to it under the bunk. I suppose you could drop the driveshaft but I wouldn't bother IMG_20200417_215351.jpg
    062 Thanks this.
