Accessing peterbilt 379 fuel splitter
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Peterbiltoo88, Apr 17, 2020.
  1. Peterbiltoo88
    Peterbiltoo88 Bobtail Member
    4
    Apr 17, 2020
    How should I access a fuel line return fliw splitter? Should I drop the front u-joint at the yoke with the driveshaft attached or drop the passenger fuel tank?
  3. Old Man
    Old Man Road Train Member
    4,597
    13,471
    Apr 3, 2009
    Oklahoma City, OK
    On my 379 the splitter is on top of transmission, you can pull the shift boot a change it from the top.
    little cat 500, Peterbiltoo88 and baha Thank this.
  4. Peterbiltoo88
    4
    Apr 17, 2020
    Old Man (Road Train Member),
    Thank you so very much for your reply. I've changed that rubber boot twice already and completely forgot about the access hatch. The screws were loose on one side on the top of the splitter. Thanks again. Peterbiltoo88.
  5. Deere hunter
    2,121
    10,024
    Aug 5, 2017
    Shallowater Texas
    You don’t have to use an original splitter you can use a brass tee works just as good way cheaper and never leaks!
    Peterbiltoo88 Thanks this.
  6. Peterbiltoo88
    4
    Apr 17, 2020
    Thank you Deere hunter (Heavy Load Member) for the great tip about the brass tee. Much appreciated! Peterbiltoo88.
    Deere hunter Thanks this.
  7. Diesel Dave
    9,684
    32,928
    Jan 20, 2010
    Hesperia, Ca.
    I replaced mine few years back. Then it started way later leaking again. I just got underneath it and tighten up the screws and it stop. It’s been 2 years and not leaked yet. The brass splitter fitting is what I’m doing next if it leaks again.
