accident advice
Discussion in 'Questions From New Drivers' started by SanJoaquin209, Dec 18, 2010.
  1. SanJoaquin209
    SanJoaquin209 Light Load Member
    192
    7
    Dec 18, 2010
    Acampo, Ca
    So this guy says I did not yield, so he had to swerve around me which led to him wrecking 200 feet down the road into a telephone pole. The Ticket was dismissed in court, but the insurance company is saying I am at fault because they are choosing to believe the other guy.:biggrin_2552: Will I receive a point on my record for this?
  3. rocknroll nik
    rocknroll nik High Risk Load Member
    4,490
    5,770
    Oct 18, 2008
    can't read the sign
    ok it was dismissed in court yet the insurance company is charging you? I'm confused:biggrin_2554:
  4. Wargames
    Wargames Captain Crusty
    3,301
    7,530
    Jul 22, 2010
    WI.
    There is not enough info. here to speculate on the accident.
  5. Wargames
    3,301
    7,530
    Jul 22, 2010
    WI.
    A major concern for truck drivers is ( or at least it should be) their driving record and how the point system will effect their employment status.
    The point system for each state varies, but there is a general rule of thumb one can utilize in order to stay on top of their driving record. The points added for violations can be more severe when operating a commercial motor vehicle in comparison to your own personal vehicle. A good guideline to use is figuring that the points for a CMV will equal one and a half times the normal point system for a personal auto. For example, in Missouri, if you are caught speeding excessively in your personal car, you will receive 3 points against your driving record. If caught while driving a commercial motor vehicle, you could figure that the number would increase to 4.5 points.
    Generally, there are variations to how many points a driver will receive for a speeding violation, based on the excessive miles per hour over the limit. A standard guideline is as follows:
    • Speeding - MPH over not specified = 2 points
    • 1-10 MPH over = 3 points
    • 11-20 MPH over = 4 points
    • 21-30 MPH over = 6 points
    • 31-40 MPH over = 8 points
    • More than 40 MPH over = 11 points
    Other violations can also wreak havoc on your CDL:
    • Reckless driving = 5 points
    • Inadequate brakes = 4 points
    • Following too close = 4 points
    • Improper lane change = 3 points
    • Railroad Crossing violation = 3 points
    • Failure to yield/stop = 3 points
    • Other minor moving violations = 2 points
    While each trucking company has their own hiring policies, on the average, trucking companies require that a new cdl driver employee have:
    • NO failed or refused drug or alcohol test within the last 3 years
    • NO reckless driving convictions within the last 3 years
    • NO license suspension for points within the last 3 years
    • NO more than 3 moving violations within the last 1 year
    • NO more than 4 moving violations and/or accidents within the last 3 years
    • NO felony convictions within the last 7 years
    • NO controlled substance violations within the last 7 years
    • NO DWI, DUI, BAC or open container violations within the last 3 years
    • NO incarceration within the last 5 years
    • NO misdemeanors involving dishonesty, theft or fraud - these are considered immediate, disqualifying events.
    Serious, major driving offenses can cause you to lose your CDL for various periods of time. These types of offenses include DUI and DWI, either in the form of alchohol or drugs, refusing to take an alcohol test, leaving the scene of an accident, using the CMV to commit a felony, driving a CMV with a suspended license and causing a fatality through negligent driving. Any of these offenses can cause you to lose your CDL for life.
    Serious traffic violations such as speeding 15 MPH or more over the speed limit, reckless driving, improper lane change and following too close, can lead to severe consequences as well. For a second offense, you could receive a 60 day suspension, and a third violation could result in a 120 day suspension. Violating an out-of-service order will result in a 90 day suspension. Violating it a second time will bring a one year suspension and a third time will result in a minimum of 3 years.
    Keep in mind, that if a CDL is suspended, the state cannot issue a conditional or hardship license. If you are convicted of a driving violation, even if it is in your personal vehicle, you must notify your employer and any points you receive will also go against your CDL. These new rules went into effect on September 30th, 2005.
    According to the Federal Motor Carrier Safety Administration, a few of the guidelines for disqualification of a CDL is:
    • 1st traffic violation = 60 - 120 days suspension
    • Two or more violations within a 3 year period = 90 days to 5 years
    • One or more violation of an out-of-service order within a 10 year period = 1 year
    • DUI, Leaving the scene of an accident, use CMV to commit felony = 3 years
    • Any of the 1 year offenses while operating HazMat = LIFE
    Safety and moving violations are taken very seriously for those who are licensed to operate a CMV. As you can see, it would not take much to reach 4-5 points on your driving record, professionaly or personally. One speeding ticket and failing to stop at a stop sign, could bring you 7.5 points on your CDL and you could find yourself out of a job. These same violations in your own personal vechicle could result in 5 points on your regular driver license . . . and could delay you from receiving your CDL for quite some time.
    The point system for each state varies, but this general format will give you a good idea on the various points one can accumulate against their driving record
  6. Wargames
    3,301
    7,530
    Jul 22, 2010
    WI.
    I believe you will have 3 points on your CDL, I posted the point system for you.
  7. Roadmedic
    Roadmedic Road Train Member
    18,951
    8,981
    Apr 4, 2007
    Those are assessed if issued and I see no way the dismissal will be of help as well.
  8. Wargames
    3,301
    7,530
    Jul 22, 2010
    WI.
    Wish him the best of luck. With no real info. I can`t really say whose at fault. He has some homework to do.
  9. ursus
    ursus Light Load Member
    75
    26
    Nov 18, 2010
    Indiana
    Quick hijack here....
    Now from what I'm reading there, a person could have been drunk and killed a few people and finally gotten out of jail for it 5 years ago and they would qualify for an entry level CDL job whereas a person could have gotten caught stealing a scarf 30 years ago and they are disqualified?
    There is no time limit on misdemeanors?
    A past felony conviction of bank robbery can be forgiven but a misdemeanor conviction of fraud cannot?
    I've seen similar lists to this on several job sites and that has always struck me as odd
  10. SanJoaquin209
    192
    7
    Dec 18, 2010
    Acampo, Ca
    I went to court for the failure to yield. Which is what caused the accident. The ticket was dismissed. No traffic school... nothing. But the his insurance company is coming at my employers insurance saying I was at fault still. They are pursuing money for his damages. Will this affect my driving record with California DMV? I was not driving a commercial vehicle, at the time it was a class c tow truck. Do you need any more information?
  11. Wargames
    3,301
    7,530
    Jul 22, 2010
    WI.
    I belive this was updated in 08`, I don`t think it has changed, but if someone else has a different point system info. Please help.
