Activating FACTORY switches / adding switch
Discussion in 'Kenworth Forum' started by Rolling18, Sep 8, 2018.
  1. Rolling18
    Rolling18 Light Load Member
    170
    34
    Dec 11, 2008
    Portland, OR
    Any one know how to add a FACTORY Back-up alarm cancel/ mute switch??
    I have seen this in many current KW
    As well as activate a "spare" dash switch to operate fog lights or other accessories?
    also like to add a factory ENG. fan switch..... can this be done?
  3. Rounded_nut
    Rounded_nut Light Load Member
    92
    107
    Feb 25, 2018
    Paccar ESA, dealer has the program and can do everything properly.
  4. Rolling18
    170
    34
    Dec 11, 2008
    Portland, OR
    thanks ill check into that.
  5. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    What model truck and engine. B cabs are way easier than the 2.1M NGP cabs.
    Oxbow Thanks this.
  6. Rolling18
    170
    34
    Dec 11, 2008
    Portland, OR
    its a 2018 t880 mx13
    Oxbow Thanks this.
  7. J Rich
    J Rich Medium Load Member
    363
    380
    May 28, 2018
    Atlanta Ga
    That truck should already be wired for the fan, and fog lights. You just have to add the lights and switch. The fan may just need the switch.
    The back up alarm will be a little more in depth, but somewhat simple. You should be able to simply interrupt the power or ground to the alarm. This could be done by cutting the wire at the alarm end, now splice a wire to each cut end I would use 12ga. You will need to run the 2 wires all the into the cab, and wire them to a on/off. There is a rubber grommet behind the filler panel under both side mirrors to pass the wires through.
    Rolling18 Thanks this.
  8. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Thought harnesses on 2.1 cabs used basic harness and have to add overlay harnesses to it. The B cab 1.9M have all the connections and wires already in the harnesses so adding features is easy. From 2.1 cab service manual:
    Harness Design and Assembly
    Introduction
    The main cab harness in 2.1 meter width cabs are
    designed and assembled differently than the 2.3 or
    1.9 meter width cabs. Instead of a main harness
    with full content and terminated connectors for
    the options, the harness will only have wires for
    the options ordered when new and will have a
    very limited number of terminated connectors.
    Any optional terminated connectors will be on the
    harness as a customer furnished option specified
    on the sales order.
    The newly designed harness receives sales codes
    as input and generates a part number generator
    for production. The harness has a 'base' for all
    standard content. The harness diagram then
    specifies different 'layers' that production will
    'overlay' onto the base harness. Once all the
    layers are installed, production will install the
    pins into the connectors and wrap up the wires
    into the final harness. Hence, this concept has
    been commonly referred to as the 'base overlay
    harness'.
    On the harness drawing the layers are
    documented in a series of reference tables. Each
    option adds electrical content to the harness,
    which, in turn creates a chassis unique harness. .
    Base overlay eliminates many unnecessary in-line
    connectors for optional equipment, and reduces
    the opportunities for loose connections in an
    electrical system
    This results in:
    • better routing
    • fewer points of failure
    • easier troubleshooting
    • fewer unused connectors
    How to Read Base Overlay Diagrams
    1. Identify the part numbers that were installed
    at the factory (authorized dealers and their
    agents will use Web ECAT).
    2. Interpret/decode the layers installed by using
    the variables of the part number broken down
    on the diagram.
    3. Look up the layer in the same diagram (later
    sheets) to identify the circuits, pins etc that
    involve the option layer.
    4. Refer to the diagram sheet that displays the
    schematic of the overlay (typically shown as
    a dashed line) which will help identify how
    the layer is physically located relative to the
    harness itself.
    5. Follow the circuit to the pin locations to aid in
    diagnosis.
    4
    pushbroom, Oxbow and Rolling18 Thank this.
  9. Rolling18
    170
    34
    Dec 11, 2008
    Portland, OR
    in my last truck i had to crawl under it every morning and unplug the Beeper.. what a pain when wet / dirty!
    thanks for the great info and future project! I have those black plastic aero mirrors.
