Im trying to add an extra battery to my semi truck so that I can watch TV and use refrigerator . Has anyone try it, or seen anyone that tried it? If so please tell me the outcome.
Adding an extra battery to the truck for electronics?
Discussion in 'Ask An Owner Operator' started by Ikamob01, Feb 17, 2022.
Page 1 of 3
I have 4 main truck batteries plus added a deep cycle rv battery to run off of when the truck is #### down. Added an isolator so if I kill the deep cycle, I can still start the truck. Working well so far.
What do you run on the rv battery and what type do you have?
I didn't put a really big one in. Has been ok for the few things I run. If I had a big inverter I'd probably get the biggest deep cycle available.Keepforgettingmypassword Thanks this.
Examples of the few things that you run?
Can you explain deep cycle. Do u run a fridge on it?
Deep cycle just means you can discharge it a lot farther and recharge it again over and over without damaging it. If you do that to a regular battery, it will quit on you pretty fast. So as far as a fridge is concerned, you could run it on either type of battery. But a deep cycle will stand up to being discharged down to what would be technically considered "dead", and recharged and wouldn't break a sweat. Do that to a regular battery a few times, and it will go bad quick.The_vett, Keepforgettingmypassword, Bean Jr. and 2 others Thank this.
12 volt cooler, fan, bunk heater and charge my phone off of it. I don't have anything too big, but just wanted to make sure I didn't kill my truck batteries in the process.Keepforgettingmypassword, bzinger and God prefers Diesels Thank this.
A deep cycle battery is a good idea because you don't have to worry about how much electricity you use from it.
But the refrigerator uses a very small amount of electricity. And the TV also uses a very small amount.
The refrigerator itself from what I understand is okay on your batteries unless you're going to park for more than 2 days at a time. So if you're going to park like three four or five days then you probably should plug into Shore power.
Overnight the fridge and the TV I don't think uses very much out of your batteries but again the deep cycle is a good idea.
The things you can't run or shouldn't run unless your truck is actually running are the high wattage items like microwave toaster oven space heater that kind of a thing. That will kill your batteries.God prefers Diesels, Keepforgettingmypassword and Bean Jr. Thank this. -
Depends on the time of year.
A fridge in the summer will kill the batteries when the truck isn't being used. If you plan on storing food.
Trucks get hot sitting in the sun.God prefers Diesels, Keepforgettingmypassword and Bean Jr. Thank this.
Page 1 of 3
