Adjusted clutch slipping again
Discussion in 'Trucks [ Eighteen Wheelers ]' started by barcaVnl, Jan 25, 2021.
  1. barcaVnl
    barcaVnl Bobtail Member
    12
    5
    Feb 16, 2019
    Hello. I used to be on here few years back. Since then i forgat my user name and password. Would visit to to read forum.
    Many of you were more than helpfull before and i need help/ advice again. My clutch started slipping ( manual , eaton 10 speed) in 9th gear few days later in 10th as well. Only slipped from 1300-1500 rpms if i took it easy on the throttle it would not slipp I took it to my shop mechanic looked at it and said more than 50% left on the clutch just needed adjustment. He adjusted it i ran over 1500 miles no slipping. Then today it slipped 2 more times , maybe a 100rpms jump i barely noticed it. So question is why would it slipp again. Iv lost clutches before , wouldnt go into a gear , slipping real bad , woudnt pull iv never expreienced nothing like this before.
    Thanks in advance
  3. Goodysnap
    Goodysnap Road Train Member
    3,773
    9,199
    Jul 12, 2017
    Hes better than me if he can tell you how much life you have left out of a manual clutch.
    Somethings wrong if its in adjustment and slipping. Time to tear it down.
  4. barcaVnl
    12
    5
    Feb 16, 2019
    Thanks for reply. Im definitely replacing as soon as i get back. I just dont know why would it slipp again if he was able to adjust it and it was fine for around 1500 miles.
  5. Rideandrepair
    17,562
    56,901
    Aug 8, 2015
    Check the linkage. Making sure there’s no worn pivots( ball joints) or bushings. Sometimes free play is due to sloppy linkage. Giving a false free play.
  6. Goodysnap
    3,773
    9,199
    Jul 12, 2017
    First things first. Is it still in adjustment? Is there any way the adjuster is stuck in? Do you still have freeplay and is it releasing fully?
    How bad was the severity of the slip the first go round and how hard did it get pushed under load. If it got hot and glazed the pads good it may loose its bite for a while. Maybe forever.
  7. barcaVnl
    12
    5
    Feb 16, 2019
    Ill have it checked for adjustment. As soon as it started slipping i took it realy easy , trying to prevent it from slipping. I think i did more than ok job slipped around 10 timed in over 3,5k miles. Cluch is fine , releases like it always has, smooth shifting.
    Dino soar, Goodysnap and Rideandrepair Thank this.
  8. harold6091
    harold6091 Light Load Member
    120
    135
    Dec 25, 2018
    hey boas dis you figure out what it was? i am having the exact same issue
