Advantages of third axle placement
Discussion in 'Heavy Haul Trucking Forum' started by Boneheaded, Apr 8, 2019.
  1. Boneheaded
    Boneheaded Bobtail Member
    30
    28
    Mar 8, 2019
    May seem to be a silly question to some. This is a question that is location specific. (Northwest Indiana/ rust belt) I am curious as to why do some trailers doing heavy haul steel have a third axle in between their 10'2" spread and some have that axle 10'2" in front of the spread.
  3. Boneheaded
    30
    28
    Mar 8, 2019
  4. Boneheaded
    30
    28
    Mar 8, 2019
    Post copied from the flatbed forum.
  5. Ruthless
    Ruthless Road Train Member
    9,184
    91,170
    Aug 28, 2010
    The City.
    3 singles vs a Tri.
  6. Old Iron
    Old Iron Road Train Member
    1,158
    20,284
    Feb 19, 2011
    NW Wisconsin
    Don't quote me but I believe in Michigan the 3 singles (Over 9' ) is good for 18,000/axle.
    Anything under a 9' spacing is only 13,000/axle.
    On the Michigan specials anyway.
    Boneheaded Thanks this.
  7. Tombstone69
    Tombstone69 Road Train Member
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    It's all about bridge weight,spreading the weight evenly across the axles so as not to damage the road surface and bridge floors. Keeps the DOT off your 6.
    Boneheaded and Farming Trucker Thank this.
  8. Rjmogf
    Rjmogf Bobtail Member
    12
    13
    Feb 26, 2019
    The first picture you posted of the tridem are 60" Canadian spreads. In Canada they can gross more on that 60" than a 40". I think it goes up to around 16,000 per axle on a 60". Here anything under 9' is 13,000.
  9. Heavy Hammer
    Heavy Hammer Road Train Member
    1,184
    5,890
    May 1, 2013
    In purgatory
    Canadian Legal tri-axle weights:
    9' front to rear (4'6" ea) is 23,000kgs/50,700lbs
    10' front to rear (60" ea) is 24,000kgs/52,900lbs
    12' front to rear (72" ea) is 25,000kgs/55,100lbs
    Canadian Permitted tri-axle weights:
    9' f to r is 25,000kgs/55,100lbs(some exceptions)
    10' f to r is 27,000kgs/59,500lbs
    10' f to r in BC is 29,000kgs/63,900lbs
    12' f to r, I dunno. Don't know anyone who runs this spread anymore
    Boneheaded, Oxbow, Humblepie and 2 others Thank this.
  10. Boneheaded
    30
    28
    Mar 8, 2019
    I don't plan to run a lot of MI loads, I'll be running in IN,IL,KY,OH,IL,MO. Am I correct that the tridem tri axle would be better for these states?
  11. Lostkeys
    Lostkeys Heavy Load Member
    903
    6,243
    Jan 8, 2011
    Archbold,OH
    I remember IL wouldn't permit me as a 3 10. They wanted the axles closer together.
