Detroit 12.7 60 series AFA rebuild kit?
Discussion in 'Ask An Owner Operator' started by thecubantrucker, Dec 19, 2022.
  1. thecubantrucker
    thecubantrucker Light Load Member
    149
    92
    Jun 2, 2019
    Hi guys detroit 12.7 60 series been hearing that those kits are good but wondering if any of you guys have used them and any personal experience with them , also cant afford oem right now so that why I'm asking
  3. W923
    W923 Road Train Member
    1,445
    4,492
    Feb 28, 2022
    Never heard of them… I would look to pai myself. We have used lots of their kits and have no complaints.
    Coffey and Rideandrepair Thank this.
  4. thecubantrucker
    149
    92
    Jun 2, 2019
    Used Pai and only lasted 2 years currently fighting teeth snd nail to get warranty using 1 gallon of oil every 2k miles at times every 1k miles and blowby is off the hook
    Rideandrepair Thanks this.
  5. W923
    1,445
    4,492
    Feb 28, 2022
    What’s the cause of the oil consumption.
    The only warranty related problem I have ever had with them was replacing a set of bearings that were damaged in shipping.
    I had a crankshaft seal on a m11 fail and they replaced it and chipped in on the labor. Other than that I have built dozens of engines with their stuff and several have made 1 million plus.
    interstate mcbee has also been great.
    Avoid reliance like the plague…their gaskets are probably made of pressed #### and will leak regardless of installation technique.
    wore out, D.Tibbitt and Rideandrepair Thank this.
  6. thecubantrucker
    149
    92
    Jun 2, 2019
    Looks like rings are weak I'm dropping oil out of blowby tube alot if it idles for 30 minutes there a big puddle underneath tube no restrictions also blowby is really bad
  7. W923
    1,445
    4,492
    Feb 28, 2022
    I just wandered if you had opened it up to look. From past experience I would expect something like a broken piston top or maybe an injector problem trashed a liner based on how bad you say it is and how it’s fairly new. Not trying to say it is or isn’t pais fault. How fast did the problem develop
  8. thecubantrucker
    149
    92
    Jun 2, 2019
    It started developing few months ago also consuming water mechanic will be opening it up tomorrow see what is going on but he told me more than likely piston rings worn out or dropped liner
  9. Rideandrepair
    17,587
    56,970
    Aug 8, 2015
    Might want to look at Mahle kits, also FP DieseI ( Federal Mogul) kits. I suggest M&D distributors. Both are good quality at a good price. Did mine with the FP. 135k now. Little bit of blow by, but I idle a lot. I know a few who used the Mahle. That was my first choice, based on their rebuilds. They were 2 mos back ordered at the time. They were in the process of buying Clevite bearing. So now their kits all have Clevite bearings, couple that with the fact they make the original OEM pistons for Detroit. Both are top notch manufacturers that have been around longer than Detroit Diesel.
    TallJoe Thanks this.
  10. thecubantrucker
    149
    92
    Jun 2, 2019
    Good stuff thanks for info and idling alot develops blowby ??
  11. Rideandrepair
    17,587
    56,970
    Aug 8, 2015
    Yes, glazes the cylinders, they say. Change oil, running it hard, supposedly helps reverse it. I’ve tried that in the past. Seems to help. It’s hard to tell. The 12.7 just have more blow by than other engines. No one seems to know why. My last Truck didn’t have any for about 5 mos. after an inframe using all OEM parts, but it started doing it after that. Current Truck had it real bad. It had well over 1 million miles on an oem inframe. It would come and go, depending on weather conditions, like humidity. Maybe just more noticeable. I expected to find a cracked ring. The valve guides were shot. I suspect that’s what caused the excessive blow by. Anyways it’s always worse when oil is old. Better after its changed. They’ll run a long time with blow by. Till the head gasket blows, maybe a cylinder drops. The bearings will hold up, almost never spin a bearing. What year is the engine?
