After Treatment
Discussion in 'Volvo Forum' started by danozar, May 2, 2016.
  1. danozar
    danozar Bobtail Member
    9
    Feb 24, 2016
    I just had a month ago replaced a failed EGR Valve and Last week I had the EGR Cooler replaced. Now a week later the truck failed to Regen and I guy hooked up a PC and I got these codes
    2637
    4214
    4282
    Can anyone tell me what are these codes for and what will be the best way to approach due to the fact that I put to much money in it already and I don't want to spend more than I have to.
    2010 Volvo with Cummins ISX engine
  3. 25(2)+2
    18,759
    45,987
    Sep 18, 2006
    the road less travelled
  4. danozar
    9
    Feb 24, 2016
    Sorry :)
    25(2)+2 Thanks this.
  5. 25(2)+2
    18,759
    45,987
    Sep 18, 2006
    I figured it was an ISX from the codes, but I thought it should be clear to anyone reading and hopefully, you will find help with the issue.
  6. danozar
    9
    Feb 24, 2016
    Was a good catch. I've updated the initial post as well. Thank you.
  7. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    Just a FYI, if you have a leaking EGR cooler replaced it's a good time to remove and cook the DPF. Coolant does bad things to it...
  8. simon999
    simon999 Light Load Member
    240
    95
    Feb 6, 2014
    Check you doser injector if its plugged you will not able to regen. Also check if there are no leaks in exhaust pipes. If there are leaks the temp is not high enough during regen.
  9. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    I would definately suggest to have dpf removed and Cleaned or baked Specialy after Replace Egr and Cooler also have to Doser or 7th injector cleaned and resealed, also check system for leaks after turbo, and one more thing on those cummins replace the boost sensor and check the lines for the delta p Sensor so they are not plugged with soot and coolant mixing up it makes all sorts of damage
    KB3MMX Thanks this.
