Aftertreatment fuses?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by NEAL1, Nov 18, 2021.
  1. NEAL1
    NEAL1 Bobtail Member
    8
    Nov 18, 2021
    I asked about this on an older thread and I'm not sure it will be seen. 2012 M2 with Cummins. Anyone know the location of the NOX sensors relay and fuses? There should be 1 relay and 2 10 amp fuses? There are not in any of the fuse boxes that I can tell.
  3. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    Under hood fuse box on driver fender.
    Heavyd and biopure22 Thank this.
  4. NEAL1
    8
    Nov 18, 2021
    I checked all those and there was no fuses or relays labeled like that. Plus, they were all good.
  5. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
  6. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    F9 is the circuit. Make sure that you have power on that fuse.
  7. NEAL1
    8
    Nov 18, 2021
    Thanks! I'll check that out.
  8. NEAL1
    8
    Nov 18, 2021
    I finally got a chance to get back in this truck. There is power on that circuit and I do have 12 volts to the outlet nox sensor but not the inlet. The schematic shows two different fuses for the two sensors. I'm starting to pull what little hair I have left out of my head! I can't locate those two fuses anywhere!
