Ag380 swap
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Jt20, Oct 30, 2017.
  1. Jt20
    Jt20 Bobtail Member
    28
    4
    Sep 3, 2016
    For those of that have done the AG 380 to the ag400 8 bag what was the process. Did u swap out all parts or just back half it... Wanting a walk through b4 I start on it ... Really wanting a better ride
  3. AModelCat
    164,689
    AG380 is a completely different suspension than the AG400. Its going to be more work than its worth IMO. Frame will need to be re-drilled to mount the hanger on each side as well as the air bags. Torque arms mount differently so you'd likely have to replace some crossmembers too. The lower bag mounts for the 400 will need to be welded to the axle as well as the brackets to bolt the waffer bars to as the 400 doesn't use u-bolts IIRC.
  4. kranky1
    kranky1 Road Train Member
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    That would be an expensive and overly complicated swap. Park next to a truck with ag400 and compare the rear-ends. You would almost have to swap the rear-ends with the suspension, and still be left with the nightmare of redrilling the frame and dealing with a mess of null holes.
  5. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,488
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    The real question is why would you want to go to 8 bag
  6. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    Have you looked at a 380 closely? They are junk! With that half moon spring and boxy spring bracket that eats bolts. The quickest way to swap to the 400 is do a cut off swap. If you don't mind your frame having a weld on each side.
  7. SmokinCAT
    1,773
    1,488
    Oct 20, 2010
    The flex air has been around for a long time, The only complaint i hear from my friends that haul heavy with it is that the bags don’t have the best lift capacity.
  8. Superhauler
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    And it is only rated at 38000 lbs. It was a poor design to begin with. Kinda like the wishbone bars were when they came out.
    Oxbow Thanks this.
  9. Jt20
    Jt20 Bobtail Member
    28
    4
    Sep 3, 2016
    Yea I get some driver that say they love it... And it rides like a Cadillac... I wonder y mine rides like a Dump truck... It's the front and rear but the rear is really rough... It's even Rough when the trailer hits the bumps
  10. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Don't get me wrong, I like kenworth but why do they have to make every rear suspention so overly complicated?
    They almost all ride like crap and wear parts out.
    What's wrong with just 4 big bags like airliner or Hendrickson. Ride really good, handles excellent and tough as nails.
    Every 8 bag setup kenworth had was terrible IMHO. Except maybe the ag100. But then that would lean like crazy in the corners if loaded heavy.
    I love my airliner in both my stars.
    Oxbow Thanks this.
  11. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    8 bags ride rough as a pallet of bricks just so you know
