AG400 Torsion Bar Alignment
Discussion in 'Kenworth Forum' started by doops22, Jan 14, 2019.
  1. doops22
    doops22 Bobtail Member
    21
    Jan 19, 2012
    maine
    I have a w900 with ag400 suspension. What holds the torsion bar centered? The front drive axle is offset to the left by a little over an inch. Doesn't seem to be any major play in the bushings, the tube is just slid over towards the driver side.
  3. AModelCat
    164,717
    Torsion bar? Are you talking the torque arms on top of the diff or the flat bars that attach between the axle and the centre hanger between the diffs?
  4. doops22
    21
    Jan 19, 2012
    maine
    Flat bars with a round tube connecting them under the axle. The schematic I looked at calls them torsion bars..
  5. AModelCat
    164,717
    I haven't looked at the AG400 suspension in a while but from what I remember there are shims that adjust the torque arms on the top of the diff. Those hold the axle centred and at the proper angle. I wouldn't mess with their alignment because you could mess up the pinion angles and cause all kinds of driveline vibrations. I would recommend taking it to an alignment shop and have them inspect the bushings and suspension components before performing an alignment.
