Air and Electric
Discussion in 'Flatbed Trucking Forum' started by Cluck Cluck, Feb 28, 2015.
  1. Cluck Cluck
    Cluck Cluck LTL Wizard
    3,795
    3,480
    May 6, 2010
    Dunkirk, Indiana
    Does anyone run their air and electric lines out the back of the frame and underneath the trailer? I'm tores of tripping over mine. On the cat walk
    If you do could you lay some knowledge on me about how you went about the electrical.
  3. xsetra
    xsetra Road Train Member
    5,198
    7,150
    Aug 21, 2011
    Plenty of trucks do that. Mostly done on RGN and stepdeck.
  4. Powder Joints
    7,996
    8,427
    Sep 25, 2007
    Rosamond, SoCal
  5. Cluck Cluck
    3,795
    3,480
    May 6, 2010
    Dunkirk, Indiana
    I fixed it. I know people do it.
  6. Rugerfan
    Rugerfan Road Train Member
    7,765
    39,822
    May 3, 2011
    Redding,CA
    The truck I'm running has that setup.. I'll ask what all it took
    Cluck Cluck Thanks this.
  7. Cluck Cluck
    3,795
    3,480
    May 6, 2010
    Dunkirk, Indiana
    Snap some photographs
    Rugerfan Thanks this.
  8. Rugerfan
    7,765
    39,822
    May 3, 2011
    Redding,CA
    I'll take some on Monday. hopefully I'm still in it then
    MJ1657 Thanks this.
  9. catalinaflyer
    catalinaflyer Road Train Member
    2,278
    Wichita, KS
    Most all of our O/O's run that setup but I can offer no insight as to what's involved in the setup.
    What I can offer insight about though is make sure you leave the normal hookups in place with valves to shut off either end that way if anything should ever happen and someone needs to move your trailer they can hook to it. We had one of our O/O's that had a medical emergency and had to leave their trailer at a customer and I wound up caging the brakes and making a jumper for the lights to recover it so they wouldn't have to pay a wrecker to move it.
    MJ1657, Cluck Cluck, BeN DaViS and 4 others Thank this.
  10. Cluck Cluck
    3,795
    3,480
    May 6, 2010
    Dunkirk, Indiana
    Oh most definitely.
    Petty Cash Thanks this.
  11. haulhand
    haulhand Road Train Member
    There should be a junction box at the back of your truck you can splice into in order to run a plug out the frame. You'll need to run an ABS wire down there tho. As for the trailer we always just cut the main wiring running back about where we wanted a plug and wired in a junction box then ran a harness where we wanted the pigtail to plug into.
