Air assisted clutch pump
Discussion in 'Ask An Owner Operator' started by Taveras101, May 25, 2024.
  1. Taveras101
    Taveras101 Bobtail Member
    Hi everyone! I just did repair my bell housing and got a heavy duty 6p clutch in my international prostar. Is it possible to replace the factory hydraulics slave pump for an air assisted one in order to get my pedal softer? This traffic out here in NJ is killing my knees
  3. snowwy
    snowwy Road Train Member
    20,527
    13,265
    Jul 6, 2009
    For the w900 there are 2 pressure plates you can pick from. 1800 lbs and 2200 lbs.
    If international does the same thing. You must have gotten the heavier plate. Instead of the lighter plate.
    The heavier plate is harder to push.
    Don't know how the system will last when more pressure is required.
    I kicked myself in the butt for going heavier on a linkage clutch. Yep. It's hard on the knee if you're stopping alot.
    Taveras101 Thanks this.
  4. Taveras101
    Thank you for the info! Is possible to place an air assisted pump instead of the one it has?
