Air bag over-inflation
Discussion in 'Peterbilt Forum' started by Money-Mike, Nov 19, 2020.
  1. Money-Mike
    Money-Mike Light Load Member
    97
    49
    Sep 27, 2017
    Old 91 Pete day cab hooked to our end dump. All of the sudden the bags over inflated one day coming down from the mountain. We have replaced the leveling valve twice, the rod down to the diff, the bags, and the shocks. It still keeps over-inflating and then constantly has air coming from the exhaust port leading to the gauge going from 90lbs to Cut-out non-stop.
    The "mechanics" at our shop are out of ideas. Anybody got any others?
  3. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    is there big drops of fifth wheel grease on the lever rod on the lever valve
  4. Money-Mike
    97
    49
    Sep 27, 2017
    Not a drop. If I drop the bags and re-inflate it levels right where it is supposed to. The minute I drive and hit a bump, it starts exhausting but the bags don't drop back down to normal.
  5. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,458
    6,865
    Oct 22, 2016
    North Dakota, Eh?
    Do you have an overinflate switch in the cab?
  6. Money-Mike
    97
    49
    Sep 27, 2017
    Nope. Just the normal and deflate options
  7. AModelCat
    164,925
    Hoses to the valve connected correctly?
    Roger McG Thanks this.
  8. Money-Mike
    97
    49
    Sep 27, 2017
    I can only assume so. Was a direct remove and replace of the leveling valve. Its just doing the same thing the original and 1st replacement were doing.
  9. mnmover
    mnmover Road Train Member
    1,237
    1,104
    Apr 5, 2009
    Lichfield MN
    Perhaps remove and replace the leveling valve with the air connections reversed. Did the leveling valve bracket get bent ? measure height of fifth wheel and put a pressure gauge inline at the leveling valve.
  10. SmallPackage
    5,814
    18,631
    Dec 20, 2019
    Marion Texas
    What brand valve or you using? The cheaper all plastic ones are hit and miss on being bad out of the box. I’ve seen one that would only shut off for a hair in the center. Barely/lightly touch it one way or the other and air would flow through it. It would never shut off like that. Neway made the oe valves for Pete and they were the best and longest lasting. More $ but trouble free. You can set them and forget about them.
  11. AModelCat
    164,925
    Installed right side up?
