Air bag pressure/ height sensor
Discussion in 'Ask An Owner Operator' started by Keepforgettingmypassword, Apr 7, 2022.
  1. Keepforgettingmypassword
    Keepforgettingmypassword Heavy Load Member
    738
    938
    Jan 11, 2022
    I am not sure of the exact name, however I just found this sensor had corroded one of the three pins off and it is stuck in the plug.
    Can I some how clean and remove this from the plug. Or am I cutting and replacing the plug also.?
    What is the proper name of this sensor.?
    It's the only air bag with a electrical plug on it.
    Thanks in advance
  3. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,082
    Sep 24, 2019
    Raleigh, NC
    often you can replace pins in a corroded out plug, just depends if it is one you can take apart.
