Air bags deflate when I remove gladhands
Discussion in 'Freightliner Forum' started by NorCalLivn, Nov 5, 2024.
  1. NorCalLivn
    NorCalLivn Bobtail Member
    29
    9
    Dec 19, 2017
    How's everyone doin? Hopefully all is well....
    I've run across this issue and can't seem to find the problem. My rig is a 2015 cascadia and has never done this.
    As of recent, every time I remove the gladhands my air bags start to release air, well, my leveling valve does. However it's only when I remove the return (blue hose). Or when I hook up to a trailer and release the trailer brakes so the trailer tank can build pressure, the leveling valve also releases air.
    The lever on the leveling valve is straight horizontal.
    Is there a check valve somewhere? I'm stumped. If there has been a thread about this i apologize. I've done searched on Google and can't find anything that relates to my issue.
    Any assistance would be greatly appreciated.
  3. SomeCanadian
    SomeCanadian Light Load Member
    168
    483
    Nov 11, 2021
    Does your trailer auto dump the air bags? The tractor will adjust to the weight shift.
    Otherwise I suspect that you might be mistaken as to where the air is coming from based on the information you provided.
  4. AModelCat
    166,491
    Blue hose is not a return line. Its your service air for the service brakes.
    Iamoverit Thanks this.
  5. NorCalLivn
    29
    9
    Dec 19, 2017
    Yea. You are correct. I miss spoke. I did have a leaking chamber but I can't imagine that would cause my leveling valve to release air when I remove the blue gladhand and or when I hook up my gladhands and release trailer brakes.
  6. FMCSA + Hazmat Consultant
    FMCSA + Hazmat Consultant Bobtail Member
    Wisconsin
    Only your airbags deflate, but your tanks stay full?
  7. NorCalLivn
    29
    9
    Dec 19, 2017
    They don't deflate as in exhaust all the air out, but almost like my leveling valve is at a 8° angle downward when it's sitting perfectly at a horizontal position. Leveling valve is about 6 month's old +/-.. It doesn't do it all the time but it just bothers me bc it's never done it before. Oh and tanks are normal/hold pressure. I did have a chamber go out and had to change my turbo actuator but no way that would cause my mysterious issue.
