air bags question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ReNeu, Nov 12, 2023.
  1. ReNeu
    ReNeu Bobtail Member
    11
    19
    Nov 12, 2023
    Alberta Canada
    I am looking for information on a air bag setup where you can have an overextended airbags on the tractor. Not sure if there is a name for that. I had one truck at work a few years ago that had the button on the dash that would lift the tractor a few extra inches. Also a co worker had a system on his truck too that he could do it from outside but I never asked how it worked as I didn't own my truck at the time. Is this special bags or just an add on? Only reason I would like to do it is for chain up situations where I need to chain everything and fronts drives are pretty tight with the fenders. tried googling it but cannot seem to get terminology to get results. Thank you
    Oxbow Thanks this.
  3. Goodysnap
    Goodysnap Road Train Member
    3,773
    9,199
    Jul 12, 2017
  4. ReNeu
    11
    19
    Nov 12, 2023
    Alberta Canada
    Thank you, well that was what I was looking for and with that I won't be adding it any time soon. Be handy for sure but 1500 US makes it lower on the want list.
    Goodysnap, BoxCarKidd and Oxbow Thank this.
  5. Banker
    Banker Road Train Member
    4,518
    14,646
    Aug 19, 2012
    It is an option on carhaulers from the manufacturer and they refer to it as a pneumatic lift kit. I ordered it on my tractor and trailer that have Hendrickson suspensions. I would have to look at the specs to be exact, but mine will raise roughly 4-6 inches.
    Oxbow Thanks this.
  6. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,956
    Oct 31, 2023
    You can do it for free if you dont mind dealing with the hassle of manually lifting the arm on the leveling valve itself.
  7. kemosabi49
    10,977
    47,916
    Jan 13, 2013
    SW Arkansas
    I would love to have something like that on my company Cornbinder. Would be nice to be able to raise the front of a rear unload tanker a few inches to get a better angle when unloading.
    Many years ago, I was pulling a van trailer for North American Van Lines that had an 11" drop. Had a switch on the front of the trailer that would allow the bags to raise the rear of the trailer up to normal dock height so I could use regular docks.
    Big Road Skateboard and Oxbow Thank this.
  8. wichris
    wichris Road Train Member
    4,498
    9,255
    Jan 17, 2011
    Had a couple of trucks than ran LTL with steep docks. Just removed the 5th wheel air line and tee'd into the air bags past the leveling valve. Flip the switch and would extend to the top of the shocks.
    mp4694330 and Big Road Skateboard Thank this.
  9. Big Road Skateboard
    7,098
    40,287
    May 2, 2021
    Definitely more than one wsy to skin a cat.
  10. beastr123
    beastr123 Road Train Member
    2,951
    24,205
    Jan 2, 2014
    Moose Jaw SK CAN
    a valve with specs such as this one
    https://www.amazon.ca/Electronic-Bo...5&psc=1&mcid=435368f1c665318cbb0e453fa4e258a7
    and connected between the height control valve and bags with a tank air supply is a quick and easy solution. height override valve.png
    ReNeu Thanks this.
  11. bavarian
    bavarian Heavy Load Member
    730
    785
    Feb 13, 2014
    Winnipeg
    That is standard equipment in Europe.
    You can raise or lower the suspension and stop at any point in between.
    Push the neutral button and it goes back to the driving position. Some may even do it once a certain speed is exceeded.
