AIR BAGS
Discussion in 'Trucks [ Eighteen Wheelers ]' started by getnitdone, May 31, 2017.
  1. getnitdone
    getnitdone Bobtail Member
    16
    10
    May 20, 2017
    When getting loaded or unloaded, do you dump the trailer air bags, or leave them inflated? Why?
  3. driverdriver
    driverdriver Road Train Member
    4,254
    5,284
    May 30, 2011
    I thought this was going to be about the posters on here.
  4. Pedigreed Bulldog
    7,737
    14,423
    May 7, 2011
    Depends upon what you're loading and unloading. If it's coming off the trailer faster than the suspension can dump air from the bags through the leveling valve (i.e. a 50,000# coil), I dump. If it's a bunch of 2000# pallets where the weight reduction is gradual, I'll leave them aired up. On an end dump, absolutely dump the suspension before you raise the bed. For a van where they'll be running a forklift in and out, you might be better off dumping the suspension (especially if you shut off the truck) to keep your air from being depleted so that when they are done, you don't have to sit there waiting for the truck to build pressure again. If you've got gauges on your suspension, you probably want to keep it aired up as you load so you know when to tell them you have enough. Etc., etc., etc...
    Too many variables for a simple yes/no response.
    getnitdone Thanks this.
  5. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,382
    Jul 16, 2012
    Bentonville Arkansas
    Dump them... less chance on blowing one
  6. getnitdone
    16
    10
    May 20, 2017
    I guess the reason I'm inquiring is because I'm wondering if there is a chance of them wearing out to the point of replacement from leaving them inflated or dumped while getting loaded or unloaded. Wasn't sure if the violent movement during either had an affect on their wear. Thanks for the input.
  7. getnitdone
    16
    10
    May 20, 2017
    Lol..... sorry to disappoint!
    driverdriver Thanks this.
