Air brake chamber failure
Discussion in 'Trucks [ Eighteen Wheelers ]' started by scoobertdoo, Sep 19, 2021.
  1. scoobertdoo
    scoobertdoo Road Train Member
    1,512
    2,603
    Nov 11, 2020
    That's a new one for me....?
  3. AModelCat
    166,070
    Ever see a cam tube crack all the way around, resulting in the can getting whipped around and smashing the diff filter off when the driver hit the brakes?
    Hammer166 Thanks this.
  4. Hammer166
    7,645
    28,033
    Aug 18, 2007
    ~8600+' and loving it!
    I had a car pull out in front of me once where I had to jump on the brakes HARD. Popped the mounting bolts right thru the can. That was on a Boydstun, it had those oddball 24/30 cans, too; they're always fun to find!
    BoxCarKidd, Bean Jr. and AModelCat Thank this.
  5. Antinomian
    Antinomian Road Train Member
    2,208
    3,507
    Feb 17, 2013
    I had a failure kinda similar to that on a steer brake chamber. The spring inside eventually wore away the metal of the casing and made a hole. A piece of the spring was actually sticking through it.
  6. BoxCarKidd
    BoxCarKidd Road Train Member
    4,574
    6,667
    Aug 26, 2014
    No! But not doubting it.
    From the different colors in the damaged holes it is apparent that did not just happen. Probably caught a gator or big rock in a pot hole or something. Then the damage grew from there. Not original but it is uncommon. Kind of like a deer antler destroying a tractor tire. Owner never heard of that and thought they were special. No just unfortunate.
    haycarter and Trucker61016 Thank this.
  7. scoobertdoo
    1,512
    2,603
    Nov 11, 2020
    Yep, most likely was mostly broken, but not pulled thru.
    I didn't even see it from the angle I do my pretrip. Saw it when I unhooked.
    BoxCarKidd and Bean Jr. Thank this.
  8. AModelCat
    166,070
    That was a fun roadside patch repair under an OD load to get it 10 minutes up the road to the shop lol.
    BoxCarKidd and Hammer166 Thank this.
  9. skallagrime
    skallagrime Road Train Member
    3,855
    9,929
    Apr 10, 2012
    Indiana
    Can only cage and replace halfback so many times before the front needs done too...
    black_dog106 Thanks this.
  10. BoxCarKidd
    4,574
    6,667
    Aug 26, 2014
    Telling your age a a bit. They were once common.
    That Twain guy once said something about learning from the mistakes of others. Thanks for sharing.
  11. Hammer166
    7,645
    28,033
    Aug 18, 2007
    I am slowly accepting the fact that after 37 years, I'm gradually being pushed into the Oldtimers Club.
    Snow Hater and BoxCarKidd Thank this.
