Air brake compressor issues
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Aggieman98, Mar 31, 2020.
  1. Aggieman98
    Aggieman98 Bobtail Member
    10
    Mar 31, 2020
    I have an 07 Freightliner century with a c15. Ive gone through 5 air compressors in 2 months. I’ve changed the air lines, governor, air dryer filter, and now dampener. Also flushed the coolant system. And ideas what could be knocking the compressors out where they won’t build air.
    1st did 4000 miles
    2nd 1200 miles
    3rd 150 miles
    4th 1100 miles
    5th 200 miles
  3. tank4life
    tank4life Light Load Member
    155
    105
    Feb 18, 2012
    Check spitter valve on the air dryer. It maybe stuck open. Also check line from compressor to air dryer for leaks.
  4. Aggieman98
    10
    Mar 31, 2020
    Put new line on compressor to air dryer
  5. Aggieman98
    10
    Mar 31, 2020
    Purge valve not leaking air
  6. tank4life
    155
    105
    Feb 18, 2012
    Did you put a new air governor on?
  7. Deere hunter
    1,935
    8,400
    Aug 5, 2017
    Shallowater Texas
    First of all are you buying these compressors from the same vendor, second the only thing that makes compressor quit compressing is your unloaders are getting stuck or your piston rings are gone! And of course your governor kicking on and off but you said you replace that!
    Also do you have a one-way valve between your compressor and your first tank somewhere sometimes those go bad and they will not let the compressor compress!
    Bean Jr. Thanks this.
  8. Aggieman98
    10
    Mar 31, 2020
    All compressors from different vendors. What’s baffling me is the different mileage I’m getting out of each one. It’s not consistent. Where would that valve be. We check air flow at each stage from compressor all the way to secondary tank.
  9. Aggieman98
    10
    Mar 31, 2020
    Yes I replaced it
  10. Dodsonf855
    Dodsonf855 Bobtail Member
    25
    22
    Mar 15, 2020
    South arkansas
    Depends on how and why they are failing?
  11. Aggieman98
    10
    Mar 31, 2020
    That what I’m trying to figure out
