Air brake:
Discussion in 'Questions From New Drivers' started by Jessis the best, Jan 17, 2020.
  1. Jessis the best
    Jessis the best Bobtail Member
    I have a class b with airbrake. I am going to get a class a. Do I have to retake the airbrake test if I have it already for my class b?
  3. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    No. But if you plan on getting anything else like. Hazmat or tanker or doubles...etc do it all at once. Or its right around 103.00 each new one you get.
    Just transferred from va to me. It was 187.00 plus 85 for the bew backtound check. All I have is hz and tanker
  4. Jessis the best
  5. Moose1958
    Moose1958 Road Train Member
    15,300
    33,975
    Dec 17, 2010
    Williesburg, Virignia
    I would recommend you be ready to test when you go to the DMV. I have been hearing some reports (but not confirmed!) from around the US over the last few years where Class B types have been told they have to retake everything including the General Knowledge test. There are a lot of (redacted) working behind those counters. On the subject of the airbrakes. It's easier to understand if you remember airbrakes is really not an endorsement, it is a test that once passed removes a restriction. This removal should follow you as you get Class A.
    dibstr and feldsforever Thank this.
  6. MACK E-6
    50,184
    240,016
    @Bigwin123 is right.
    Hazmat isn’t an easy test, but doubles and tanker is. They’re worth getting.
    feldsforever Thanks this.
  7. dibstr
    dibstr Road Train Member
    1,308
    932
    Sep 10, 2010
    Here in MS when upgrading from B to A they do require you to retake the General Knowledge test. What seems even sillier to me is that if you have no air brake restriction on your B, you do not have to take the Air Brake test. So if you have no AB restriction on a B you have to take GK and Combo tests to get an A.
  8. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    When I was in class getting my cdl. There were students that came is week 3 of 5 week course. I was told these were the Class B drivers. Tho they left once they had their class A credential
  9. Roadgeek395
    Roadgeek395 Light Load Member
    208
    345
    Jan 24, 2017
    In California if you upgrade from a Class B to Class A you have to retake everything.
  10. brian991219
    brian991219 Road Train Member
    3,030
    6,231
    Aug 10, 2013
    Lords Valley, PA
    In most states you will not have to retake the air brake written knowledge test, however you will have to do the in-cab portion again as the air brake leak down and physical test is slightly different from class B to A. You will also need to properly identify and inspect the air brake components on the truck and trailer during the pre-trip portion of the skills test.
