Air Brake
Discussion in 'International Forum' started by MajorWaste, Feb 9, 2017.
  1. MajorWaste
    MajorWaste Bobtail Member
    Guys, I have a 96 DT466P that has air brakes, I had to replace the motor with a used DT466 that had hydraulic brakes so no air compressor. When I pulled the Power Steering pump the gear on the pump is smaller than the one on the air compressor. My question is, is there just a gear swap on the air compressor to a smaller gear to fit on the other motor or do I have to pull the timing cover and change all the gears to fit the original gear on the air compressor.
  3. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    I took a quick look, both engines should be the same, it is the accessories that are different. I can't seem to remember any further details about that. Do you have any pictures?
  4. MajorWaste
    Well the gear on the power steering is smaller than the gear on the air compressor, I am thinking the bull gear needs to be changed only. Interstate in their infinite wisdom could not make the gears the same size
  5. Heavyd
    7,826
    6,276
    Feb 4, 2009
    See if it bolts up nicely. I think the power steering should mesh the same. From what I see the rear half of the front cover pieces and the idler gears are the same between the two set ups. I am thinking the power steer pump must be bolted offset slightly so it can run a smaller gear and still mesh properly.
  6. MajorWaste
