Air brakes using to much air
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 377pete, Oct 30, 2016.
  1. 377pete
    377pete Light Load Member
    147
    14
    Oct 26, 2009
    dfw
    Got a pete 377 thats acting up. its a dump.truck with a pup trailer. brakes are adjusted and no air leakes. when its emty the brake guage only goes up to 15 psi when applying the brakes and stop really good. with the truck and pup loaded the brakes suck, uses up to 60 psi and i have to apply brakes several times and run out off air and buzzer comes on. cant find any leaks
  3. 4x4_Welder
    4x4_Welder Medium Load Member
    300
    213
    Sep 16, 2014
    Eastern Orygun
    Leaking wheel seals, worn out shoes, bad slack adjusters, or any one of a number of other issues.
    Have you had anyone hit the brakes while you watch the chambers and mechanical bits?
  4. AModelCat
    166,336
    Not sure I'm following what you're saying. Is your issue poor stopping power from the brakes? Or is it a lack of reservoir capacity? Or is it a lack of reservoir capacity because you are constantly pumping the brakes?
  5. AModelCat
    166,336
    If stopping power is the issue, I'd be checking the linings for contamintation or glazing. If its a lack of air reservoir capacity, I'd try and drain the air tanks from full down to completely empty. Trapped water in the tanks will reduce their capacity.
    LGarrison and ExOTR Thank this.
  6. ExOTR
    ExOTR Windshield Chipper Extraordinaire
    1,706
    1,893
    Jan 23, 2013
    Fort Worth, Tx
    This is a good point, if you don't bother to drain the trailer tank it might be 70% water. I've drained well over a gallon out of trailer tanks, don't think many people bother to open the drain valve. Only thing I miss about running doubles is everyone left the valves open when they dropped.
    BoxCarKidd and G13Tomcat Thank this.
  7. 377pete
    147
    14
    Oct 26, 2009
    dfw
    I have drained the tanks, slacks adjusters are all 8 months old and brakes linings. had my son step on brake pedal and everything is functioning . its my braking power. like their is a delay when the truck is loaded.
  8. swaan
    swaan Road Train Member
    2,942
    4,376
    Jul 12, 2009
    BC canada
    Maybe its the brake lining and or drums itself. Ive seen some lining look really good but when they get old they get hard and or glazed and dont stop worth a dam.
    If you have proper air pressure confirmed with a gauge at the pots then id replace your lining and drums with fresh stuff before you kill someone.
    wore out Thanks this.
  9. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    If the drums are glazed, you aint stopping.
    If the diagphram between the spring chamber and the stroker chamber that adds power to your slack adjusters to apply the pads to the drums are bad, you will leak through there.
    If your pads are glazed or cooked, you aint stopping.
    If your drums are cracked on the inside from too much heat you aint stopping.
    If you cannot get inside a certain stroke distance you aint stopping.
    04 LowMax Thanks this.
  10. BoxCarKidd
    BoxCarKidd Road Train Member
    4,579
    6,675
    Aug 26, 2014
    Straight trucks and buses are required to have a brake inversion valve. One of those systems malfunctioning can cause what you are describing.
    Oxbow and x1Heavy Thank this.
  11. 377pete
    147
    14
    Oct 26, 2009
    dfw
    The shop found a bad brake chamber on steer axle and a valve .
    x1Heavy Thanks this.
