driver was at intersection and when released peddle the brakes didn’t release. Trooper called tow truck and when they showed up they pulled gladhands from trailer and air released and freed up brakes. $400 charge. Is this the foot valve going bad?
Air brakes
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Jasonar15, Dec 14, 2017.
It sounds more like feedback in the trailer than the foot valve. If it was the foor valve, you would have it in the truck too.
Most likely you have a brake chamber that is back-feeding or a bad relay valve. I would go to a shop and have the trailer brake system checked. -
Oh, then check the valve then for issues. It may have bound air in the system.
Sounds like you may have found the issue. That caused the brakes to stick.
Jasonar15 Thanks this. -
It was grimlins everyone knows that.
