Air Compressor Leaking Oil?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by PE_T, Oct 10, 2019.
  1. PE_T
    PE_T Road Train Member
    I think my air compressor is leaking oil. It’s not really leaking on the ground. I’m seeing some black oil under the compressor. Is it time to replace the air compressor? This is on a 2014 Freightliner Cascadia DD15. I don’t think the air compressor has ever been changed.
    Lane=addict Thanks this.
  3. wkbmarine
    wkbmarine Bobtail Member
    Jun 4, 2024
    I know this is a very old post, but my compressor is wet with oil at this exact spot. I recently had the overhead run and this leak showed up a couple of days later. Did you ever determine what the issue was on yours?
  4. bad-luck
    bad-luck Road Train Member
    3,432
    6,323
    Nov 16, 2013
    Baltimore, Maryland
    Usually when it starts leaking like that, it is at the end of its life.
  5. Lane=addict
    Lane=addict Light Load Member
    147
    163
    Aug 12, 2024
    Earth
    Get a new compressor sounds like the right plan.
  6. 062
    062 Road Train Member
    6,328
    33,969
    Oct 20, 2013
    Depending on mileage, the o-ring may have gotten hard allowing oil to leak.
    Rideandrepair Thanks this.
  7. Rideandrepair
    17,553
    56,872
    Aug 8, 2015
    I agree with 062. Is that the fuel pump mounted at the end? If so, maybe just a gasket or o ring.
    062 Thanks this.
  8. 062
    6,328
    33,969
    Oct 20, 2013
    Power steering pump
