Air compressor safety valve keeps purging
Discussion in 'Freightliner Forum' started by MercerDriver, Apr 11, 2017.
  1. MercerDriver
    MercerDriver Light Load Member
    69
    7
    Sep 3, 2010
    Atlanta, GA
    Just started recently on my 2003 Detroit DDEC4 engine.
    On the compression cycle, the safety valve on the compressor itself keeps purging air. The more RPM, the more frequent it is.
    Checked air supply hose to air dryer: no kinks or bends. Took out the unloader valve: looks good, greased it up just in case put it back in, problem persists. On the "off" cycle, everything is okay.
    Can the air dryer purge valve be the problem? Please help
  3. AModelCat
    164,642
    Well what's your air pressure? Those little safety valves are designed to vent at around 150 psi. If its venting at a lower pressure I'd change out the safety valve first. They're only a couple bucks.
  4. MercerDriver
    69
    7
    Sep 3, 2010
    Atlanta, GA
    Air pressure seems to be okay. Compressor kicks into compression mode around 105 psi and kicks off at around 130 psi.
    One thing I did forget to mention is that the dryer purge valve doesn't purge air at end of the compression cycle. That's why I thought it was the purge valve that's bad.
    Does the air pressure in the cabin get its info before or after the dryer? If after, maybe it is over 150 psi, and I'm just not seeing it on the gauges?
  5. kemosabi49
    10,977
    47,915
    Jan 13, 2013
    SW Arkansas
    When was the last time your air dryer was serviced. I had one that was so full of stuff that it couln't purge right anymore.
  6. MercerDriver
    69
    7
    Sep 3, 2010
    Atlanta, GA
    Governor, filter cartridge, purge valve all replaced about 1.5 years ago. By the way, it's a Bendix AD-IS dryer. Seems like I'm having 2 problems at once.
    1. Compressor safety valve keeps popping on compression cycle although dash gauges show regular psi
    2. Purge valve won't dump air out at 130 psi. The compressor somehow shuts off by itself without the valve purging.
  7. MercerDriver
    69
    7
    Sep 3, 2010
    Atlanta, GA
    Replaced air purge valve, problem solved. The old one had lots of crud and oil on it. Must have been stuck in the closed position, building up pressure.
    TheBaron97 and xsetra Thank this.
