Air compressor ticking sound
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Cajuncowboy654, Jan 6, 2021.
  1. Cajuncowboy654
    Cajuncowboy654 Light Load Member
    138
    34
    Jun 4, 2019
    I recently changed the governor and the 1/4" line from the governor to the compressor, now i notice an air leak with a ticking when the pressure gets into range to have the compressor start pumping again.
    Anyone know what this could be?
  3. 201
    201 Road Train Member
    12,791
    26,319
    Apr 16, 2014
    high plains colorado
    Not your air dryer ticking, is it?
  4. Cajuncowboy654
    138
    34
    Jun 4, 2019
    I was able to catch it today. Its coming from the purge valve.
    When it gets to around 100 psi and starting to compress air again it will start sputtering air from the purge. Is it the purge valve that's bad, or unloader maybe??
  5. tj379
    tj379 Light Load Member
    237
    226
    Nov 10, 2019
    ontario
    do u mean u replaced the quarter inch air line from governer to dryer?, if your building air as normal at 100 psi i would believe your unloders are ok, i would ceck your check valve in dryer
  6. Cajuncowboy654
    138
    34
    Jun 4, 2019
    No I replaced the quarter inch line that comes off the compressor to the governor on the dryer.
    When the air gets down around 100 is when it happens, it expels aire from the purge valve with a pulse to it.
    When it gets over 120 psi it purges as normal.
    tj379 Thanks this.
  7. pup
    pup Light Load Member
    252
    256
    Dec 3, 2011
    n.h.
    If the problem started right after the governor change I'd look there. Be sure you didn't plug the exhaust port on the governor.
    tj379 Thanks this.
  8. tj379
    237
    226
    Nov 10, 2019
    ontario
    ahhhh got ya! i was assuming ur govener was compressor mounted, obviously it is not, im not real familiar with that newer style of dryer but same principle should apply, your compressor and unloaders are working correctly, your signal line is new, so nuthin left but dryer and or check valve in dryer, i would just replace it as a whole but i believe those can be pricey compared to a ad-9 as im used to
    650cat425 Thanks this.
  9. Cajuncowboy654
    138
    34
    Jun 4, 2019
    I wouldn't say it started after. It just got worse.
    It would do it intermittently before now it does it every time.
    I mounted the new governor exactly like the old one. Just plugged what was plugged and left open what was left open.
