Air compressor volume problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dirty old man, Sep 7, 2019.
  1. Dirty old man
    Dirty old man Bobtail Member
    6
    Sep 7, 2019
    Hi men, fng here. Need advice.
    I recently bought a 2005 379 pete with cat power. My problem is this truck is very very sloooow to build air. I thought compressor, changed it this morning. Nope, 400 bucks thrown away. So I thought spin on filter at air dryer. Nope. Did the soap suds test at the exhaust vent at the bottom of air dryer, no bubbles. Checked the intake for obstructions, nothing.
    Whats next to check or replace?
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,551
    6,641
    Aug 26, 2014
    soap test all the lines while it is building air.
    spsauerland and Dirty old man Thank this.
  4. pushbroom
    pushbroom Road Train Member
    1,791
    7,403
    Sep 1, 2012
    I have had discharge lines collapse internally making it very slow to build. Did you disconnect the governer line off the air compressor to verify it wasnt faulty?
  5. Dirty old man
    6
    Sep 7, 2019
    Not yet. I’ve seen fuel lines do that very thing. Will check that first tomorrow. I did crank it with filter off and volume supplied there is very low.
  6. Dirty old man
    6
    Sep 7, 2019
    The lines to the air dryer have a good flow. The port coming out is way less but its not leaking out of the exhaust port. Seems like the dryer is bad but i cant understand why the relief valve at compressor isnt popping off if there is an obstruction. I sprayed down the entire dryer with a soap solution. No bubbles.
    I should mention too that once the air pressure is built up, the truck will hold pressure overnight.
  7. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Air inlet blockage maybe
    Dirty old man Thanks this.
  8. Dirty old man
    6
    Sep 7, 2019
    Checked that too. Thanks tho because I am open to any suggestions. I have seemingly checked everything but the right thing......
  9. BoxCarKidd
    4,551
    6,641
    Aug 26, 2014
    By pass the dryer. If air builds properly replace it.
  10. Dirty old man
    6
    Sep 7, 2019
    Thanks. Didn’t have the right fittings today. This one has one big flare fitting inlet and two half inch tubing outlets.
    My 98 pete had a dryer that you could just pull the in and out lines and thread them directly together.
    BoxCarKidd Thanks this.
